Occasional skipping only on big cog?
Results 1 to 8 of 8
    Oct 2005
    I have a 1x11 drivetrain on my MTB which had always worked great. I checked the chain and saw it was due for a replacement so I did. Shortly after I noticed a skip every now and then when under load in my lowest gear.
    If the cogs/chain ring were worn into the old chain I would expect this to happen when on the smallest cog (fewer teeth to grab) but it doesn't.
    The derailleur works fine so I don't think the cable tension is to blame and I don't see how replacing the chain would require adjustment to the limit screw.
    Could a new chain somehow exaggerate an issue with chain line when in that gear even though the old one didn't?
    'brifter' is f'ing stupid
    Yes. Most likely related to chain wear.
    #promechaniclife
    Nov 2002
    The cog you use the most will probably be the one that skips.
    Some chains are directional, so is yours run the right way?
    I'd check the low gear limit screw and the derailleur cable adjustment. That can cause the chain to skip.
    A tight link can cause a chain skip. Rotate the cranks backwards to see if the there's a tight link that bobble through the derailleur pulleys.
    If none of the above works, you probably need to replace the cassette.
    Reputation: Oxtox's Avatar
    Aug 2006
    recently replaced the chain and it immediately started skipping when climbing in small / big.
    figured the cassette was toast, so ordered a new one...
    while waiting for it to arrive, kept riding the old one and after 50 miles, the skipping stopped. didn't install the new cassette and have had zero issues in 2800 miles.
    Dec 2006
    This.
    Feb 2002
    Quote Originally Posted by Oxtox View Post
    This has been my experience too. If the cassette is "on the edge" of wear, a new chain will bed in after a few miles and the skipping will resolve. I've seen it take much longer than 50 miles, but it beats replacing the cassette. I've worked on the assumption that when the new chain is worn out, by then the cassette will be totally worn and this trick won't work for a 3rd new chain. Haven't tested it though.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    IF you use a Wippermann link and installed it reversed this may happen. Just something to check.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Oct 2005
    This has been my experience too. If the cassette is "on the edge" of wear, a new chain will bed in after a few miles and the skipping will resolve. .
    I'll be darned, it's been about 70 miles since I posted this and it does indeed seem that the skipping stopped.
    Cool.
  1. Replies: 2
    Last Post: 12-16-2013, 05:48 PM
  2. Chorus 11 skipping in 11th cog
    By Bizman in forum Campagnolo
    Last Post: 08-31-2012, 05:34 PM
  3. New 105 setup -- chain skipping on one cog: suggestions?
    By bike981 in forum Components, Wrenching
    Last Post: 11-13-2011, 01:47 AM
  4. chain skipping on 11 cog
    By Fixed in forum Components, Wrenching
    Last Post: 12-11-2009, 11:35 PM
  5. Replies: 0
    Last Post: 04-13-2005, 05:28 AM
