Older style Campy Centaur Ergopower Left Shifter with Compact Chainset
Results 1 to 10 of 10
    Mar 2020
    Question Older style Campy Centaur Ergopower Left Shifter with Compact Chainset
    Hi Folks,
    New here so bear with me please
    I picked up a used 2005 Cervelo Soloist Centaur with a compact chainset (2 rings). The left shifter feels like it has 5 clicks for indexed shifting so it becomes incredibly cumbersome to shift the front during a ride as to move up it takes 4/5 shifts and then the chain starts to rub so i have to pull it back a bit.
    Is there anyway to tune this properly?
    Thank you in advance.
    Tino
    'brifter' is f'ing stupid
    You're not pushing it one click at a time are you?
    #promechaniclife
    Feb 2002
    Quote Originally Posted by tinof View Post
    Hi Folks,
    With a Campy front shifter, you typically do three or four clicks at once to accomplish the shift. Think of it as a friction shifter with detents. Think of "sweeping" the shift. Sounds like a technique issue given the information offered.
    Mar 2020
    Trying not to
    Used to Shimano shifting, first time with Campy - is this the technique for newer campy stuff?
    Mar 2020
    Trying not to
    Mar 2020
    Thanks Kerry, asking the same Q to you as well. Is this even with the newer campy stuff?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Trying not to
    In the space of the last 20 years...Campagnolo has changed the innards and out-ards of their shifters about a dozen times all totaled.
    Feb 2020
    Can't speak for Kerry, or to all Campy, but current Potenza no on the front, the sweep back to the big ring has no detents. I don't think current SR does either, or at least I didn't notice it.
    Reputation: nova_rider's Avatar
    Sep 2005
    The Potenza group has Power-Shift system, and I believe your Centaur does too. Chorus level and higher (Record & SR) have Ultra-Shift system. The main difference between the two is with how the shift buttons behave.
    On the Power-Shift, the left(front) shift button drops to the small chainring with a single push. However, on the Ultra-Shift, it has indents to allow for more positioning of the FD, but arguably slower downshift. For the right (rear)shift button, Power-Shift only allows for single upshift per push whereas Ultra-Shift has indents that allows for multiple cog change in a single button actuation, or quicker upshift. I believe the idea is to simplify shifting and minimize unintended shifts for lower-end groups, but this also means that the Power-Shift system is more sensitive to misalignment or improper adjustments.
    The lever behavior on both systems should be the same.
    Nov 2009
    Quote Originally Posted by nova_rider View Post
    Centaur became PowerShift in 2011, along with everything else below Chorus
    2009-2010 it was Ultrashift, although the 2009 detents were weak. There was a carbon brake blade option with the same 337g / pair weight as Record.
    2007-2008 it was Escape which also had an escapement mechanism like PowerShift
    2002-2006 it had the classic G-spring design
    2001 it was named Daytona and identical to 2002 except for the logo
    A 2005 shifter has 12 positions IIRC, of which 3-4 are used for doubles and 6-7 triples.
    2009-2014 Ultrashift left levers have 6 or 7 positions of which 3-4 are used for doubles and all for triples.
    With G-spring and Ultrashift levers you can go directly from small to big ring and vise versa pushing the front paddle and button farther.
    If it takes more lever actuations you don't have enough cable tension or there's something mechanically wrong with your shifter.
    Pointy hood g-spring right levers through 1997 can shift directly from largest to smallest cog. Ultrashift levers can go 5 smaller.
    I never used 1998-2008 round hood G-spring, Escape, Powershift, or 2015+ levers.
  1. Replies: 5
    Last Post: 04-22-2014, 07:34 PM
  2. New style 10sp Centaur levers on Old style 10sp?
    By Hillen in forum Campagnolo
    Last Post: 03-05-2011, 06:39 PM
  3. Centaur Ergopower or Ergopower Ultra Shifters
    By pulser955 in forum Campagnolo
    Last Post: 06-07-2010, 11:22 AM
  4. Replies: 3
    Last Post: 03-25-2010, 10:18 PM
  5. Campy Record Ergopower acting like triple chainring shifter?
    By abquid in forum Components, Wrenching
    Last Post: 12-27-2009, 03:31 PM
