painting/coloring cable housing?
Results 1 to 12 of 12
    Reputation: nayr497's Avatar
    Nov 2008
    Anyone tried and had success painting their cable housing? Yes, yes...I know cables and housing aren't that costly, but these are all pretty new and in fine working order. Would like to change the color of them though, as I'm changing a few things around on the bike.
    This is on one of my road bikes and there is very little cable housing exposed...runs from the end of the bartap to the headtube. Then just two small other pieces of housing, one at TT to rear brake, one at the RD.
    Probably some sort of decent quality spray paint would be fine, just have to figure out protecting the frame against overspray.
    Thanks!
    gazing from the shadows
    Jan 2003
    Quote Originally Posted by nayr497 View Post
    You would have to remove them, there is no way you would get coverage on the bike.
    Paint is brittle, and will crack and flake if put on anything that moves/flexes. You will need to look for flexible paint, which is a thing (different types exist). Still might not work.
    You might be able to use dye. Very light wet sand to scuff, it should take dye. Probably not cheap fabric dye, but quality dye, which should not increase the circumference of the housing like paint would.
    Colored housings are available. Not every shade in the world of course, but many colors. Once you factor in paint/dye costs and potential failures and time, that's the way I would go unless looking to get a SUPER custom color.
    In conclusion, black. Black goes with everything.
    Nov 2008
    Yeah...I was figuring this is more trouble than it is worth and I just need to recable it. I'm capable of doing it myself, just not much free time in the near future. Then again, there is very, very little housing on this bike.
    Yeah...black! I set this bike up with a lot of white parts, but then I did a full white out on another bike, so I'd like to make this bike mostly black. It currently has white housing
    Oh well, I enjoy tweaking the looks of my various bikes, so this will just be another project to work on in the future.
    Thanks for the reply!
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Nooooooooooo.... just...noooooooooooooo.
    Nov 2008
    I know, I know. Point(s) taken. I'll just live with the white housing until I get some time to recable it. Thanks for setting me straight. It's way too nice of a bike to mess around with anyway.
    Banned forever.....or not
    Aug 2002
    If you look on Amazon, you can find housing in different colors.
    Dogbert.
    I>U
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Definitely not paint but heat-shrink tubing may do the trick, but as inexpensive as housing is new housing is the best choice.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Oct 2013
    Tape, lots of colors, and just wrap it at an angle.
    BANNED
    What the what???
    Jul 2009
    Jagwire comes in a variety of colors. I have orange on one of my bikes.
    https://jagwire.com/products/housing
    The Law of Headwinds states: If the ride out is easy you better leave something in the tank for the turn...
    Apr 2014
    Painting cable housing probably takes longer to do than just changing the housing itself. But if you're really hell bent on painting it, I would suggest either plasti dip it or just use a sharpie. You do know that paint or plasti dip will make the housing weigh more.
    'brifter' is a lame word.
    Quote Originally Posted by upstateSC-rider View Post
    You have got to be kidding...
    I work for some bike racers
    and a bunch of skateboards
    Russian Troll Farmer
    Sep 2016
    If you didn't have 1,477 posts, I'd be certain that this was a troll post.....
    "L'enfer, c'est les autres"
  1. Can you use a shifter cable housing as a brake housing?
    By bmwjoe in forum Components, Wrenching
    Last Post: 04-07-2013, 11:42 AM
  2. coloring tires?
    By jmitro in forum Wheels and Tires
    Last Post: 11-20-2011, 01:23 PM
  3. Coloring tire sidewalls with sharpie hurt tire?
    By TZL in forum Wheels and Tires
    Last Post: 03-29-2010, 03:31 PM
  4. Internal Brake Housing...Cable Housing....
    By spepic in forum Components, Wrenching
    Last Post: 07-14-2008, 05:40 PM
  5. Ugh.... Pokemon Coloring Pages and Porn
    By funknuggets in forum The Lounge
    Last Post: 05-31-2008, 09:21 AM
