Peugeot Fixed Gear / Crankset
Results 1 to 4 of 4
    Sep 2002
    Hello, I picked up this Peugeot Fixed Gear recently but wanted do something about the remaining double crankset (the 52 ring is one piece). Does this look replaceable or does that get into BB replacement, chainline issues, etc? Or, any chance I dremel tool/cut off the 52 ring after/outside the chainring bolts leaving just the inner / 42? Pics attached. Or just leave it as is? (seems like some sort of violation to have a fixie bike with 2 chainrings pcrank1.JPGpcrank2.jpgpcrank3.jpgpcrank4.jpgpcrank1.JPGpcrank2.jpgpcrank3.jpgpcrank4.jpgThanks!
    'brifter' is f'ing stupid
    Yes it's replaceable. Whether you can find a crank that will work w/ that bottom bracket to get you the correct chainline is another story. Most likely yes, you just have to know what you're looking for.
    #promechaniclife
    Reputation: nova_rider's Avatar
    Sep 2005
    Definitely replaceable. Looks pretty standard from the pics, but can't say for sure unless it's pulled off. Also, teeth on SS chainring is cut differently to keeps the chain on, so I probably wouldn't ride the 42 without the big chainring. Besides, SS cranks are dirt cheap, even if you need a new BB.
    Quote Originally Posted by nova_rider View Post
    Not on a SS or fixed road bike. Unless you mean 1/8" instead of 3/32" but it sounds like you're talking about narrow/wide like a 1X, but it's not like that. Completely normal ring, no pins or ramps.
    #promechaniclife
  1. Fixed Gear Nation - gallery of fixed gear bikes
    By dave_sloan in forum Fixed/Single Speed
    Last Post: 03-17-2016, 08:19 AM
  2. Replies: 8
    Last Post: 06-06-2012, 02:55 PM
  3. fixed/fixed on a fixed/free hub?
    By Hollywood in forum Fixed/Single Speed
    Last Post: 02-27-2010, 09:13 AM
  4. weight loss with fixed gear/ need help with gear inches
    By kroettger1 in forum Fixed/Single Speed
    Last Post: 12-22-2006, 09:52 AM
  5. Cheap fixed gear contest over at the fixed forum
    By Dave Hickey in forum General Cycling Discussion
    Last Post: 11-01-2006, 07:45 AM
