Pinarello Aria 1" fork Question
Results 1 to 5 of 5
    rock n rolling resistance
    Reputation: 6was9's Avatar
    Did your Aria fork come with an expander plug? Mine didn't.
    Who makes/carries 1" expander plug?
    Also does anyone know what year Pinarello stopped supplying Aria fork with their frames?My guess is 03.
    And does anyone know what is pre-03 Pinarello seatpost size? 27.2mm post seem to fit awfully tight.
    some help...
    I assume your fork has a 1" carbon steering tube. Supergo sells a universal expanding plug.
    If a 27.2 seatpost fits in snugly, that's undoubtedly the correct size. The next smaller size is 27.0 and that would fall into the seat tube. Perhaps the seat tube needs a minor interior sanding to remove burrs or paint.
    Nov 2002
    Quote Originally Posted by 6was9
    What frame are you riding? I have a 99 Paris with the Aria. My fork has an steel steerer so I don't need an expander plug. I use the star nut. Also, my Paris uses a 27.2 post.
    Russ
    Jan 2002
    My '02 Opera
    has the Aria fork, which came with the expander and a top cap. The post is 27.2 and the fit is fine.
    eminence grease
    Reputation: terry b's Avatar
    My 01 Opera uses the Aria and it came with a Pinarello branded top cap/expander plug. Through my ham-fisted ignorance, I managed to round out the pre-load hole and had to replace it. I'm now using an FSA generic 1" expander.
    Also using 27.2 Chorus Ti post with no fit problems. It's snug, but it's not impossible. Steel is funny, get a little layer of oxidation in the tube and getting the post in can be a challenge.
  1. Opera fork Question...
    By 6was9 in forum Other Builders
    Last Post: 05-17-2004, 06:55 PM
  2. Ouzo Pro fork insert question
    By Kerry Irons in forum Components, Wrenching
    Last Post: 04-23-2004, 04:15 PM
  3. Cracked my Pinarello fork
    By JFR in forum General Cycling Discussion
    Last Post: 04-02-2004, 03:20 PM
  4. cheapest place to buy a Alpha Q cx fork 1"
    By Lemondpoprad in forum Cyclocross
    Last Post: 03-15-2004, 09:36 AM
  5. calling all 1" carbon fork owners
    Last Post: 03-14-2004, 12:14 PM
