Pins and ramps
Results 1 to 8 of 8
Thread: Pins and ramps
    Reputation: velodog's Avatar
    Sep 2007
    Pins and ramps
    I'm running an IRD sub compact Defiant crank with an 11spd group, and everything is starting to show wear. My question centers on the chainrings, IRD doesn't offer replacement rings for this crank and the only 94BCD rings I can find are TA, quality pinned rings but they have no ramps.
    Anyone know how replacing a pinned and ramped chainring with one that has pins, but no ramps, will affect shifting. It's 46/30, so a large jump, but the front derailleur handles it easily, with the ramps and pins. I ride the drivetrain as a 1x with a granny, so I really don't front shift that often, but I need it to shift cleanly when I do. The rest of the drivetrain is Campagnolo, if that matters, but I don't think that it should.
    Running as a 1x with granny means a lot of cross chaining, and that is what is causing the wear, not hooking, but side wear on the outer surface of the teeth.
    Too old to ride plastic
    Reputation: Srode's Avatar
    Aug 2012
    I've found on more than one occasion (at least with) Shimano, I could find a crank for less than new rings. Might want to look on Ebay for a crank and see what you can find there in good shape. With a 16 tooth jump I would want all the help I could get on that shift happening myself.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Sep 2007
    In theory this is a good plan, but if I was going to go a new crankset I sure would like a Compass\Rene Herse and that is just shy of $500 and would probably need a new narrower bottom bracket, it calls for a 110 spindle and my current is 115, and like I said, I cross chain.
    But, yeah, all the help shifting I can get is what led my to asking, I'd hate to buy the rings and then have dicey shifting.
    What the what???
    Jul 2009
    Since you run it mostly as a 1X, have you considered going with a larger cassette to get the granny gear and use just a single ring up front? I did that a while back with a ten speed setup and liked it so much I eventually went full SRAM 1X11.
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
    Sep 2007
    Quote Originally Posted by Opus51569 View Post
    No, that doesn't appeal to me. I like having the close ratio transmission that I'm running, while still having those low gears. A 1x, while giving me the low gearing does it at too high of a price, which are the larger jumps between gears that a wider range cassette demands.
    Feb 2002
    Another description of 1X for road riding is "often not able to find the best gear." If you never ride on flat roads, this is less of an issue, but if you want to ride a few miles on a flat road and have only "too big" and "too small" choices, it's a pain. Give me that "straight block" cassette every time. I run a 12-25 11s.
    Sep 2007
    I live right outside Chicago, so I always ride on "flat roads".
    I been running a 12-25 also, but I use the 12 so infrequently that I just got a 13-25 to use when I retire the 12-25. I'm coming up on 20,000 miles on the drivetrain with 3 chains in rotation, and things are starting to get tired. I've been playing with the idea of rotating thru 4 chains when I swap everything out, but I've got plenty of time before I need to decide.
    What the what???
    Jul 2009
    Makes sense.
    Yeah, I've heard that too, but with my flat Midwestern ride that hasn't been the case. The two tooth jumps in the middle of the cassette are where I live most of the time and they seem pretty comfortable to me. To each their own I suppose.
  1. Do cassette shift ramps wear out?
    By bleckb in forum Components, Wrenching
    Last Post: 03-27-2016, 02:00 PM
  2. quality silver 48 or 50 tooth 130mm outer 9 speed chainring with ramps/pins?
    By Henry Chinaski in forum Components, Wrenching
    Last Post: 01-20-2015, 05:32 PM
  3. Promoters, ramps and paint
    By pbayne in forum Cyclocross
    Last Post: 09-08-2009, 07:38 PM
  4. What are: brifter, BB and ramps?
    By iks in forum Beginner's Corner
    Last Post: 08-22-2006, 05:06 AM
  5. "Shift ramps" on chainrings, how much are....
    By packfill in forum Components, Wrenching
    Last Post: 01-08-2006, 09:20 AM
