Please help me identify a clicking sound
Results 1 to 10 of 10
    Reputation: barnott's Avatar
    Aug 2013
    I'm going a little nuts with this one. Just got back from a 20 mile ride. 18 of which, I was serenaded by a click.
    • Cadence magnet is not touching the cadence monitor.
    • While pedaling, the click happens when the right Ultegra crank/pedal hits the 1 or 2 o'clock position.
    • No click when coasting.
    • Click keeps time with my cadence.
    • Click disappears when there is no foot pressure on the pedal. In other words, when I hand crank it, no click.
    • I vaguely feel the click in my foot.
    • There doesn't appear to be any obstructions anywhere.
    I got caught in the rain on my previous ride. I whipped the bike down, cleaned the chain, lubed the chain.
    I almost had a nutty after 15 miles of this sound. The bike is only a month old.
    What could this be?
    thanks
    Reputation: Fignon's Barber's Avatar
    Mar 2004
    I would bet that this is the solution: Take both wheels off the bike. Clean the area where the wheels are attached (fork and rear dropouts) and also clean area around quick release where it contacts bike. Put the wheels back and tighten quick release. I am 99% sure you will be silent. Deposit one rep point in FB account.
    Aug 2013
    Quote Originally Posted by Fignon's Barber View Post
    I will give that a try. Thanks!
    Banned forever.....or not
    Aug 2002
    Take the baseball cards out of your spokes.
    Dogbert.
    I>U
    Jan 2013
    Could be bottom bracket or pedal, since you say it only happens under pressure and you feel it in your feet. If FB's fix doesn't work bring it back to the shop. It's only a month old they should fix it.
    Feb 2002
    Quote Originally Posted by barnott View Post
    What could this be?
    thanks
    It is fairly common to have clicking noises, but ticks and clicks are very hard to eliminate sometimes. What seems like it is tied to the pedals may be coming from the seat post, etc. Sometimes things like temperature and humidity can affect noises as well. Also, things like the front derailleur cage just hitting the crank, loose bottle cage bolts, or the front derailleur cable sticking out and hitting your shoe can seem like they are clicks but really aren't. Another thing to consider is that the frame and components are flexing from pedaling forces, and so you can get a click or creak sound where you think it couldn’t be – for example the seat post & clamp can make noise even when you are standing and pedaling due the frame flexing. Here’s a link if you don’t like reading the rest of this post: Bicycle Touring Tips, Lessons Learned, and Tricks of the Trade
    Clicks tied to your pedaling can come from
    - BB (grease all threads in contact with the frame and BB, all metal to metal contact surfaces, and torque to the recommended settings, which can be quite high), the faces of tapered BB axles if they have a little corrosion
    - bolt holding the BB cable guide onto the frame (grease threads and make sure the bolt is not touching the BB shell inside the frame)
    - crank bolts (grease threads and washers)
    - chain ring bolts (take them all out and grease the threads, the faces where they contact the CRs, and the CRs where they contact the crank spider arms)
    - a dirty chain, inadequately lubed chain, stiff link in a chain or a burr on one of the "break off" special links used to assemble the chain
    - front derailleur clamp (clean and put a light film of grease on the inside of the clamp where it touches the seat tube)
    - the pedals (grease the threads and the shoulders of the axle where it butts against the crank arm, get some wax, silicone etc. on the cleats, check for play in the bearings, squirt some lube into the guts of the pedal machinery if possible)
    - shoes/cleats - loose cleat nut rattling around in the shoe sole, shoe/cleat interface, cleat bolts, cleats touching pedals (wax lube, silicone, or furniture polish)
    - seat post and saddle (grease the post, seat post bolts, saddle rails, and add some oil to where the rails go into the saddle body)
    - bars and stem (grease the stem where it clamps to steerer or goes into the steerer if quill type, top cap, stem bolts at both ends, h'bar bolt if quill stem, and h'bar where it goes through the stem)
    - grease/tighten QRs and where the hub axle contacts the frame
    - tighten cassette lock ring, grease cassette hub body and cassette spacers
    - grease steerer tube spacers (if threadless)
    - replaceable derailleur hangers (remove, clean, grease all parts and threads, reassemble)
    - any other bolt (bottle cages, derailleur clamps, derailleur bolts, shift cable casing stops, etc.)
    - cables hitting the frame (cable donuts), or shifting in their end ferrules (lube contact points).
    Wheels can make noises when pedaling or coasting (check for spoke tension, particularly on the rear non drive side, put a drop of lube where each pair of spokes cross and where each spoke enters the rim and the hub flange, check for loose metal bits or spoke nipples in the body of the rim and cracks in the rim at spoke holes.).
    Jan 2010
    If it coincides with cadence, then it's not the wheels.
    #1 cause in my experience is pedals or cleats. Check pedal spindle & bearings. Check cleats for wear and tightness of screws. Check soles of shoes.
    There's sometimes a buggy.
    One.
    Aug 2013
    This is great! I have some direction now. Thank you very much. I will let everyone know what I discover.
    Jul 2012
    Your crank arm is hitting your derailleur.
    Reputation: Dave Cutter's Avatar
    Sep 2012
    I'm going a little nuts with this one. Just got back from a 20 mile ride. 18 of which, I was serenaded by a click........
    ........ I got caught in the rain on my previous ride. I whipped the bike down, cleaned the chain, lubed the chain.
    ....... the front derailleur cable sticking out and hitting your shoe can seem like they are clicks but really aren't............
    Kerry Irons has lots of great information in his post. But if you just washed your new bike I'd say [my meaningless best guess] would be your shoe tapping the cable.
    If I didn't bicycle when the weather is bad... I wouldn't be a cyclist. I'd just be another old fat man... with a bicycle hanging in his garage.
    Urban Cycling.... Overcome your fears (a YouTube Link).
    Learn to cycle in traffic
    Or... just HTFU
  1. Clicking sound while riding
    By TonyV1 in forum Components, Wrenching
    Last Post: 09-13-2012, 06:51 PM
  2. Clicking sound......Help
    By Muaythaibike in forum General Cycling Discussion
    Last Post: 03-18-2009, 06:50 PM
  3. Please help with clicking sound
    By Dirty Bird in forum General Cycling Discussion
    Last Post: 04-17-2008, 06:14 PM
  4. clicking sound
    By cctitans in forum Beginner's Corner
    Last Post: 03-20-2008, 06:03 AM
  5. clicking sound
    By soulsurfer104 in forum Components, Wrenching
    Last Post: 08-23-2004, 07:31 AM
