puzzling cottered crank
Results 1 to 8 of 8
    Jun 2004
    I encountered a crank today where the non drive side is held on with a cotter and the drive side is fixed to the bottom bracket axle. The shell is not threaded and uses pressed in cups of smaller diameter than a schwinn. The cups appear to be non removable. All the preload on the bearings is accomplished via adjusting outer races threaded onto the crank arm.
    the owner damaged the BB axle, i'd like to find a square taper adapter but they appear to be for the larger schwinn and i don't see any cranks like this on ebay.
    The bike is a Futurematic 3 speed made in Austria.
    Reputation: velodog's Avatar
    Sep 2007
    picture?
    Too old to ride plastic
    Feb 2002
    Quote Originally Posted by jroden View Post
    The joys of proprietary systems. Just as much a pain today as in the ancient history when this bike was made.
    Russian Troll Farmer
    Sep 2016
    Chances are that if it's Austrian, it's made by Puch. If there is a forum for classic Puch bikes somewhere, this setup might be known.
    "L'enfer, c'est les autres"
    Jun 2004
    Thanks, from lookin at the "touring" bikes it appears to be a Puch. Still no luck on finding that oddball crank
    Dec 2005
    Or Austro-Daimler - I think Puch made their bikes at some time.
    Sep 2016
    Quote Originally Posted by ogre View Post
    I believe that they are one in the same today.
    wim
    wim is offline
    Feb 2005
    I'm pretty sure the bike has what's known as a Thompson bottom bracket. The chain wheel, drive-side crank and axle on these Thompson units are often swaged together to form one piece, like the one in the video at the link seems to be. The German term for such a bottom bracket is Thompson-Innenlager in case you need to search for a European vendor. These Thompson bottom brackets were popular for a long time on many brands of lower-end European utility bikes, so it's not a proprietary design.
    https://www.youtube.com/watch?v=U3NFZ_zD5as
    For what it's worth: An earlier version of the Thompson bottom bracket had the non-drive side crank arm press-fitted onto the axle taper. There was no cotter. The only way to get that crank arm off was with a puller, or by driving it off the axle with repeated blows from a large hammer.
    https://www.youtube.com/watch?v=tQsIXv4JUGA
  1. Mavic QRM+ bearing adjustment puzzling me
    By paulfeng in forum Components, Wrenching
    Last Post: 12-17-2011, 11:38 AM
  2. Mavic QRM+ bearing adjustment puzzling me
    By paulfeng in forum Wheels and Tires
    Last Post: 12-17-2011, 09:36 AM
  3. Puzzling blowout
    By ericm979 in forum Components, Wrenching
    Last Post: 06-16-2008, 06:36 AM
  4. cottered crank BB removal - need help
    By Ronin1 in forum Retro-Classic
    Last Post: 11-15-2005, 05:02 PM
  5. Cottered Crank Arms
    By kirrill in forum Retro-Classic
    Last Post: 06-02-2005, 06:34 AM
