R7000/R8000 front derailleur with Campagnolo Shifters
Results 1 to 5 of 5
    May 2012
    I have older Record 10 speed Ergopower shifters with eleventy billion clicks on the left hand lever and find the cable tension adjuster on newer Shimano FDs interesting as I can lose an inline cable adjuster between the bars and frame.
    Beyond the Frankenbike issues which I don't really care about, will a R7000/R8000 FD play nice?
    'brifter' is f'ing stupid
    No idea...try it out and let us know. I'd think the odds are in your favor.
    #promechaniclife
    Feb 2002
    Quote Originally Posted by Bremerradkurier View Post
    Campy front shifter is essentially a friction shifter. Unless there is a big difference in cable pull such that the Shimano requires a lot more cable movement than the Campy shifter can provide, it should work fine. In my opinion, the Campy concept is a far better one than the "big bang shift with trim" Shimano approach.
    Reputation: JCavilia's Avatar
    Sep 2005
    Campy front shifter is essentially a friction shifter. . .
    I agree, though I'd say RATCHETING friction shifter.
    Yeah, highly likely that it will work, especially since those Campy shifters could handle triples, so there's a lot of movement available.
    "None of us knows for sure what's out there; that's why we keep looking. Keep your faith; travel hopefully. The universe will surprise you, constantly." The 13th Doctor.
    May 2012
    Did it with the R8000 FD and it works great-the maggot screw adding an extra contact point and microadjustment of cage alignment is a great feature.
    I anticipate that the steel cage will last a lot longer than a Chorus or higher FD with a carbon outer plate.
  1. Problem with R8000 front derailleur
    By Ken2 in forum Components, Wrenching
    Last Post: 12-24-2018, 03:48 PM
  2. Shimano 105 R7000 Crankset Spacing
    By jchau in forum Components, Wrenching
    Last Post: 11-06-2018, 07:01 PM
  3. Replies: 3
    Last Post: 10-22-2018, 07:11 PM
  4. Did my new r8000 derailleur cough up a bushing?
    By OldZaskar in forum Components, Wrenching
    Last Post: 05-21-2018, 09:20 AM
  5. Cannondale R7000??
    By rangerdavid in forum Bikes, Frames and Forks
    Last Post: 06-16-2009, 02:42 PM
