Rattling water bottle cage
Results 1 to 7 of 7
    Feb 2013
    I have a Trek Domane SLR. The one screw for the bottle cage on the down tube will not stay tight and bottle cage will start rattling every other ride. The screw goes into the Cover that holds the Di2 battery. Threads are good and I can get screw as tight as I dare but always ends up getting loose. Definitely donít want to use loctite.
    Reputation: nova_rider's Avatar
    Sep 2005
    Have you tried using a longer screw?
    Dec 2006
    Use blue Loctite, #242. Don't brush it on ALL the threads; try 1/2 to 1/3. It's meant to be removable.
    If you still don't want to use it, try Teflon pipe sealant, otherwise known as plumber's dope. It's a white, Fluffernutter-like goo. Never hardens.
    Feb 2013
    think Iíll try a little blue loctite. Not going into frame but into Di2 battery mount. Shouldnít have to take that off till battery fails which hopefully is not for awhile. Amazing how much noise that cage makes rattling
    Reputation: velodog's Avatar
    Sep 2007
    If worried about Loctite try a dab of nail polish or paint, it holds but doesn't have the strength of Loctite.
    Too old to ride plastic
    Sep 2011
    Just a thought, but maybe you need a shorter bolt. Is it possible that the bolt is bottoming out and not actually keeping the cage tight?
    Feb 2013
    Bolt length is okay. It goes right through the plastic Di2 battery mount into the down tube. I did notice that on another bike the bottle cage bolts have an o-ring on them. Going to see if this makes any difference before using loctite.
  1. Saddle bag or second bottle cage with tool bottle?
    By kevina6 in forum Bikes, Frames and Forks
    Last Post: 06-28-2017, 04:01 AM
  2. What water bottle are you using with Elite bottle cage
    By ch3360 in forum Beginner's Corner
    Last Post: 08-28-2012, 11:06 PM
  3. Replies: 16
    Last Post: 01-04-2012, 10:20 AM
  4. Aluminum water bottle or metal water bottle, save your money
    By ARP in forum Components, Wrenching
    Last Post: 06-04-2008, 04:00 PM
  5. Bottle can't fit into bottle cage of same brand!
    By Jared in forum Components, Wrenching
    Last Post: 11-04-2005, 08:41 PM
