RDR cage wobble
Results 1 to 13 of 13
Thread: RDR cage wobble
    Reputation: Srode's Avatar
    Aug 2012
    RDR cage wobble
    So I can rock my RDR cage quite a bit on my gravel bike, more so than my road bikes. Is there a bushing / pin I can replace to tighten that up? The allen screw is tight.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    'brifter' is f'ing stupid
    Too much information...no idea.
    #promechaniclife
    Aug 2012
    there are 2 allen headed bolts that hold the cage sideplates together and the jockey wheels in place. The top one holds the cage to the DR mechanism. It's that point that it rocks back and forth, the DR isn't moving it's the cage where it attaches to the DR, moves sideways not front to rear. Does that help?
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    No. What brand? Which model? And I'm nearly positive the upper pulley bolt doesn't hold the cage to the body no matter what derailleur it is.
    #promechaniclife
    Aug 2012
    Sorry, I thought I put that in the first post but obviously I didn't. Shimano RD-R8050 GS Cage.
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    The upper pulley bolt doesn't hold the cage on. I've never seen one 'loosen up' because the bolt that does hold the cage on got loose...I have seen the pivot bushings in old derailleurs get sloppy.
    #promechaniclife
    Aug 2012
    the dealer diagram shows there's a T10 bolt that holds the plate axle in the DR but not bushing that I can see. The plate axle comes with the cage plate I think. Is there a bushing in the DR body itself that isn't showing in the diagram? I can see about tightening the T10 but it's only supposed to be 1nm torque, looks like it's to retain the fixing pin not hold it from rocking to me from the way it's designed.
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    I'm talking about the bushings in the body, there are 4 of them. Not serviceable. The plate axle is part of the inner plate. That T10 is just a retainer. If there is enough movement for it to be a problem I'd have a dealer try to warranty the derailleur.
    #promechaniclife
    Aug 2012
    It's over 2 years old and I'm not the original owner so probably not something I can get warrantied. Probably best to just get a replacement, maybe a GRX RD-R815 since it has a bit wider range of cassettes (not per spec but based on user's feedback).
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Feb 2002
    Is the thing not shifting properly? If so, replace it. If not, you are probably overthinking this. As cx has said, there is nothing you can "tighten" that will reduce what you are seeing.
    Aug 2012
    yeah, it's not shifting well regardless of how I adjust it, and the chain doesn't have that many miles on it, like 2500. My other Di2 bikes shift crisply. I ordered a RD-RX815 this morning for it. When it get's here I'll put it on and take the 8050 apart and see what is worn out of curiosity.
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Aug 2012
    New DR fixed the shifting, nice and crisp now like my other bikes. I measured the chain vs a new one laid out on the floor next to a new one and zero stretch
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Good to hear that fixed it.
    (chains don't stretch)
    #promechaniclife
  1. Replies: 0
    Last Post: 10-28-2019, 10:23 AM
  2. Short Cage vs. Med. Cage
    By Sympatico in forum Campagnolo
    Last Post: 06-29-2005, 05:42 AM
  3. Rear Derailers - short cage vs. long cage
    By ravenmore in forum Components, Wrenching
    Last Post: 03-18-2005, 04:41 PM
  4. short cage to medium cage Chorus
    By Jdub in forum Components, Wrenching
    Last Post: 08-07-2004, 06:08 AM
  5. Long cage - short cage...
    By TurboTurtle in forum Components, Wrenching
    Last Post: 08-05-2004, 05:21 PM
