Really Small Tubing that the Der. cable runs though at the bottom bracket.
Results 1 to 3 of 3
    Reputation: edorwart's Avatar
    Aug 2007
    Does anyone know where I can get the tubing that you put over the front der. cable as it goes through the bottom backet guide and then up though the frame to the front der.? I have tried to find it. The LBS says "it comes with the bikes" and they do not have it. It is smaller than any tubing at a hardwear store.
    Thanks,
    Erik
    Apr 2005
    In one of my frames, I used a piece of the smallest cable housing I could find. Then I stripped the coating off of it and it fit perfectly. I had to tap it in with a rubber mallet, but then it is permanent and It works great.
    Climbin' Clyde
    Reputation: Sablotny's Avatar
    Aug 2002
    I second that emotion
    I have bits of old housing that are too short for much. So every once in a while I'll strip the outer linings (plastic and wire) and pull out the teflon (?) inner sheathing for this use.
