Rear cassette tandem failure
Results 1 to 10 of 10
    Feb 2011
    Riding up a steep incline on the tandem on the weekend and something started to make noise. As we crested the top, the chain was dancing on the rear cassette. Upon removal of the cassette, I find that the carrier has cracked at each of the four arms at the "rivets" which hold the individual cogs onto the carrier.
    This is a 9-speed mountain cassette, 11 x 32, a CS-M750 made by Shimano.
    Common failure mode? We're probably 350 pounds all-in, including the bike. The hill was 19% for maybe 50 feet. Our gear is a 28 up front with the 32 in the back, often can do the short climb in the 28 in the rear, but we weren't feeling that spunky and did it in the 32 instead.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Can't say if it's a common failure mode. But 350lbs on a 19% climb.... dang that's some torque on the cassette! Not surprised at all.
    Sep 2011
    I've never seen this before.
    Oct 2005
    Me either but I'm also not too surprised. Two strong riders on a tandem can lay down a lot of torque. On steep climbs my wife and I would regularly flex the frame of our MTB tandem enough to cause chain suck with brand new drive chain components in good adjustment.
    You may also have had a small nick/gouge at the rivet on one arm that acted as a stress-riser. Once that one arm broke the others didn't have the strength to hold together. I once had a crank arm fail because of this.
    Also, I think part of the design strategy for XT parts is to shed weight. But while a lightweight part may be strong enough for a single rider it might not be up for tandem use. Maybe replace that with a lower-end non-spider cassette?
    gazing from the shadows
    Jan 2003
    Quote Originally Posted by dir-t View Post
    XT seems to be sold at many tandem specific retailers, so I doubt it is a common problem. But it might be a known issue for advanced and strong tandem riders.
    Might want to browse/ask on some tandem specific boards for this one. Tandems are their own thing in many ways.
    Feb 2002
    Quote Originally Posted by bike867 View Post
    Many years ago my then 14 year old daughter and I drove the pawls of a freewheel right into the body, deforming the metal. That is hardened steel at the ratchet surface. Tandems combine a heavy load with a large power source. Component failure often results. If companies made "tandem specific" components for these high-load applications, hardly anyone would buy them because they would be "too heavy."
    Reputation: OldZaskar's Avatar
    Jul 2009
    350 lbs, 19% grade... and still less torque/force than one 160 lbs pro sprinter. I'd chalk it up to a fluke. Or just fatigue from thousands (?) of miles.
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by OldZaskar View Post
    Power maybe. Torque... no.
    A pro sprinter putting out 1500w at 120rpm generates 119Nm Torque (1050 in-lb). With a 172.5 crank arm, that's a force of 154lbs. (The max force a 160lb person could exert on a crank arm is ~160lbs and 1100 in-lbs)
    Torque (N.m) = 9.5488 x Power (kW) / Speed (RPM)
    Two grown men weighing 150lbs each, standing on a climb, would generate about 2000 in-lbs of torque. The forces on the cranks, chain, and gears are significantly higher than a pro sprinter. But at 30rpm it's only 700w so the power is much less. Power is force over time.
    Jul 2009
    Why... because he weighs 160lb?
    tlg
    tlg is offline
    May 2011
    Yea. Maybe a little more using the bars as leverage.
    The math is pretty simple. A pro sprinter putting out 1500w at 120rpm has a crank force of 154lbs.
    If a pro sprinter was putting out the torque of two standing riders, at 120rpm, it'd be 2,900w.
  1. Trek not liable for failure to warn of carbon fiber failure
    By RichardT in forum General Cycling Discussion
    Last Post: 03-21-2015, 05:56 PM
  2. Home made tandem bike rack/fuji tandem
    By moonie in forum Tandems
    Last Post: 11-30-2013, 05:59 PM
  3. Frackin Hard Drives. . .Failure on Failure
    By Ridgetop in forum The Lounge
    Last Post: 05-21-2010, 09:46 AM
  4. Replies: 1
    Last Post: 05-20-2010, 05:15 AM
  5. Replies: 1
    Last Post: 08-08-2006, 06:44 AM
