Rear Derailleur Advice 1x set up
Results 1 to 13 of 13
    Sep 2018
    Thanks in advance to any advise given.
    A good friend of mine is switching his road bike to a 1x set up to eliminate having to change gears in the front due to a hand injury.
    We currently have a shimano ultergra 11 speed shifter (drop shifter), a 11-42t rear cassette installed and have the front 1x chainring installed. 40t. We are now looking for a rear derailleur. Can anyone verify if this one will work:
    https://bike.shimano.com/en-US/produ...M9000-SGS.html
    My main concern is does the type of shifters make a difference when picking a derailleur? MTB shifters vs road bike drop shifters? As long as itís all shimano is it all compatible?
    Thanks again for any input you can provide.
    'brifter' is a lame word.
    Why don't you just use a bar-end shifter on the right side? No, the road shifters are not compatible w/ the mtb rear derailleurs, at least not 11 speed.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2018
    I guess it could be a option to go with the bar end but he just bought the new Ultegra 11 speed shifter so Iím sure he would prefer to use it. Anyone know if Shimano has a compatible derailleur with the set up Iíve described above?
    Oct 2013
    BANNED
    That does NOT work w/ the cassette the OP is intending on using.
    OP: I mean use the 11 speed shifter for the rear AND use the left side bar end shifter on the RIGHT side to control the front derailleur. Set up a bike like this for a para athlete I worked with a few years ago.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    According to the Shimano compatibility lists, the only RDs that support 40-42 cog are in the new GRX line, BUT the Ultegra shifter isn't marked as compatible with those.
    https://productinfo.shimano.com/#/co...544&acid=C-255
    Edit: I don't know why they aren't listing other road shifters as compatible, maybe because they aren't differentiating just using the left shifter vs the right and all the other shifter sets are 2x. I would imagine the Ultegra right shifter will work fine since the RD-RX812 literature says it is road cassette compatible.
    Anyway, check out the GRX Series RD-RX812, might be your best bet.
    Sep 2018
    I was confused about what you meant at first but yea thatís a good idea. Fullishly I never even thought of that. Though I will add we are not bike mechanics. He brought up the idea of going to a 1x set up, we started playing around with bike gearing calculators online, figured out gearing that we thought would work and started ordering stuff to take to his local mechanic to install. Everything is now installed but the rear derailleur. At this point Iím hoping we can find one that will work but if not your bar end idea may be what we have to do.
    thanks again for all input
    Sep 2018
    We ordered the Shimano GRX RX812 as suggested. Iíll update the thread once itís all installed.
    Quote Originally Posted by XxJamesAxX View Post
    Have fun with that...according to the Shimano Compatibility chart the GRX 812 rear derailleur ONLY works w/ the ST-RX 810 and ST-RX 600 shifters.
    Sep 2018
    I guess we shall see, I found multiple sources that claimed " It is compatible with current road dual control lever shifters so upgrading is simple." including Shimano's website.
    https://bike.shimano.com/en-AU/product/component/grx-11-speed/RD-RX812.html
    Maybe I'm misinterpreting that line but fingers crossed.
    I hope to have a update next week.
    Neophyte
    Jul 2007
    Smile
    I'm hoping it works out for OP and friend. If the RD is meant to work with road cassettes, how could it not? I still think they did the compatibility chart the way it is because they list the shifters as sets and there's no reason to have a 2-speed right shifter (such as 6800 or R8000) with the GRX line in general.
    If it doesn't work, sorry for the suggestion.
    Edit: Oh, I see there is 2x for the GRX line. I forgot about that. Anyway, fingers crossed for you.
    Sep 2018
    Happy to report the Derailleur works perfectly with the Ultegra shifter. The mechanic said installing/tuning was no issue.
    Thanks again for all input given.
    Good to know...now that I think about it I can't understand why Shimano would make those so shifters non-compatible w/ Ultegra, I was just going by their chart.
  1. Ultegra rear derailleur 6700 max cog 1x set up
    By khardrunner14 in forum Cyclocross
    Last Post: 01-11-2017, 12:23 PM
  2. Replies: 3
    Last Post: 12-25-2015, 06:51 PM
  3. Replies: 0
    Last Post: 12-25-2015, 05:29 AM
  4. Replies: 10
    Last Post: 10-09-2014, 07:54 AM
  5. Rear wheel build 1x/radial nds 2x ds
    By 2Bills in forum Wheels and Tires
    Last Post: 09-25-2013, 04:14 PM
