Rear derailleur compatibility, does # of speeds matter?
Results 1 to 7 of 7
    Twitterpated
    Reputation: T-shirt's Avatar
    Aug 2004
    Question Rear derailleur compatibility, does # of speeds matter?
    I was just wondering. If I have say 10 speed indexed shifters, must I have a 10 speed rear derailleur?
    Does the shifer regualate the amount of cable available to move the derailleur up and down the cogs? Does the derailleur handle any of the indexing or does it just "follow orders" from the shifter? I don't even know if a derailleur has to travel farther on a 10 speed than it does a 9 speed with similar #'s of teeth...I just guessed that they've been spacing the cogs closer together.
    Just wondering, thanks.
    Tshirt
    Call me a Fred
    Reputation: MikeBiker's Avatar
    Mar 2003
    Deraillers just follow the shifters commands. The shifter determines how far the derailler moves. It doesn't matter is the derailler is 8 or 9 or 10, it will shift however far the derailler lets it.
    Mike
    You may starch my jumper
    Hang it upside your wall
    You know by that, baby
    I need my ashes hauled.
    Sleepy John Estes
    H
    NeoRetroGrouch
    Reputation: TurboTurtle's Avatar
    Quote Originally Posted by MikeBiker
    Some do use different pulleys on the RD. I believe there is are different pulleys between Shimano 8 & 9 and between Campy 9 & 10. - TF
    "Don't those guys know they're old?!!"
    Me, off the back, at my first 50+ road race.
    Twitterpated
    Aug 2004
    MikeBiker,
    That makes sense. Thank you very much for your help.
    Tshirt
    Twitterpated
    Aug 2004
    TurboTurtle,
    I didn't know that some had different pulleys; I wonder if that affects the performance. That's good to know. Thank you.
    Thanks
    Tshirt
    Reputation: merckx56's Avatar
    Aug 2004
    Quote Originally Posted by TurboTurtle
    I've used 9 speed with 8 speed derailleurs in the past and they work perfectly. Same with 10 speed drivetrain and 9 speed derailleurs. The derailleur moves within the spacing. The shifter determines the amount of cable pull. (For Shimano)
    Shimano pulleys are very slightly different...not enough to really make a difference. Campy pulleys are different and mixing and matching 9 and 10 speed produces varied result.
    If you ride Shimano-don't buy a derailleur if yours still works.
    If Campy- spend the $$
    Pretty much here just to piss you off...
    Twitterpated
    Aug 2004
    merckx56,
    Very good, thank you. It's good to know that other people have experience with this. My BB is Campy...and the bike is a single speed, so I guess spending dough was unavoidable.
    ;) I'll look for a 10 speed. Thanks for your advice.
    Have a great weekend,
    Tshirt
  1. Ultegra 9sp rear derailleur cage size?
    By cityeast in forum Components, Wrenching
    Last Post: 10-10-2004, 06:18 PM
  2. Ultegra triple rear derailleur on a double?
    By ljmeier in forum Components, Wrenching
    Last Post: 09-26-2004, 06:32 PM
  3. Shimano 105 double cranks w/ 105 triple rear derailleur?
    By Bike junkie in forum Components, Wrenching
    Last Post: 07-13-2004, 07:46 PM
  4. derailleur compatibility
    By toothlesscog in forum Cyclocross
    Last Post: 06-09-2004, 08:47 AM
  5. 10sp Dura Ace rear derailleur
    By Dave Hickey in forum General Cycling Discussion
    Last Post: 04-02-2004, 07:52 AM
