Rear derailleur shifter doesn't "click" anymore
Results 1 to 6 of 6
    Mar 2004
    I have an older (1998) set of Mirage 8 speed shifters and the rear derailleur ergo shifter doesn't make the clicking noise anymore when you shift up or down. It still shifts either direction, but it is not precise, more of a continuous shift without the click. I went to brandford bike to try and figure out which part might need to be replaced, but really don't have any idea. Does anyone know what part I would need to fix this? Here's the link with the parts diagram: http://www.branfordbike.com/brake/brk04b.html
    Thanks.
    May 2002
    At a minimum you might need part #4 but better get #6 and #9 as well.
    Every little counts...
    Reputation: Spunout's Avatar
    Aug 2002
    Call them, you`ll need a standard re-build kit with the springs and stuff, once you have it apart, get the whole job done!
    Feb 2002
    Sluice & lube first
    Before going the rebuild route, you should first flush it out with WD-40 (or any aerosol solvent) and then squirt some TriFlow or ProLink in there. Shift through the gears many times while doing this. It may just be gunked up rather than needing a rebuild. If the problem exists after the sluice & lube, you're not out anything and you can procede with the rebulid.
    Chili hed & old bike fixr
    Reputation: curlybike's Avatar
    Jan 2002
    Quote Originally Posted by divve
    On the 8 speed shifters the g springs and button return spring are the only things that routinely fail. Out of a bunch of 8 speed ergo levers I have had to replace 1 g spring carrier and I have never seen an index wheel fail . It is a shame that the button units and the button return springs are not available from Branford .
    Mar 2004
    Quote Originally Posted by Kerry Irons
    Thanks, I'll try this 1st.
  1. rear derailleur adjusting???
    By noavg55 in forum General Cycling Discussion
    Last Post: 05-29-2004, 06:31 PM
  2. barcon shifter + SRAM derailleur?
    By split in forum Cyclocross
    Last Post: 05-05-2004, 11:50 AM
  3. 10sp Dura Ace rear derailleur
    By Dave Hickey in forum General Cycling Discussion
    Last Post: 04-02-2004, 07:52 AM
  4. sticky shimano 105 rear shifter
    By gdugs in forum Components, Wrenching
    Last Post: 03-26-2004, 03:03 PM
  5. Wear on a DA rear derailleur
    By mtpisgah in forum Components, Wrenching
    Last Post: 03-15-2004, 12:22 PM
