Rear shifting problems
Results 1 to 25 of 27
    Apr 2007
    Okay, so I was caught in a rainstorm last Friday. Over the weekend, I cleaned the bike and notice the rear shifting is not cooperating. It shifts fine from the small cog to the largest, but does not go back down very well. It hangs up and will eventually shift down with a lot of hesitation.
    I lubed all the pivot points on the rear derailleur but not much of a change. Would the next thing to do is change the cable housing? Any other suggestions for me to look into?
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    Check for gunk in your bottom bracket cable guide and then maybe some spray lube in your brifter.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Cables and housing. Absolutely.
    Do you have steel galvanized cables? Getting them wet can easily oxidize them and cause corrosion which will drag inside the housing, preventing your derailleur from shifting down.
    First thing I would do is replace the cables with good stainless cables. Chances are you won't need to replace the housing.
    'brifter' is a lame word.
    Quote Originally Posted by hfc View Post
    Check for gunk in your bottom bracket cable guide and then maybe some spray lube in your shifter.
    ftfy...
    Depends on how old the cables/housing are. You could have a cable fraying inside the shifter, or it might be time for new cables/housing because of wear/dirt in the housing or your derailleur hanger might be out of alignment.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2007
    I did check for gunk when I cleaned the bike. Besides, this is a mountain bike converted to be road friendly as my commuter, and the cables come from the top.
    Tig,
    I think you nailed it. I had been having issues with my shifters and had to replace the cables not long ago. Unfortunately I only had the cheap galvanized cables as a spare. I just threw them on as I had them laying around. I didn't realize they would cause a problem so quickly. Also, being in Southern California, I was caught by surprise with the last storm.
    Will replace the cables.
    Thanks.
    Also, what is a good housing that anybody would recommend in case I need to replace this too?
    Quote Originally Posted by Deering View Post
    Tig,
    Thanks.
    Anything from a reputable manufacturer is good. Shimano, SRAM, Jagwire...all good. I would definitely replace the housing, the crap galvanized cables will have created wear inside the housing liner.
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    ^This^
    Unfortunately I only had the cheap galvanized cables as a spare. I just threw them on.......
    Throw them away!
    Feb 2002
    While the cable suggestions are good, shifting fine in one direction and slowly in the other are classic signs of the need to tweak the barrel adjuster. Try turning the barrel a quarter or half turn and see if that improves things. If it gets better but is not quite there, give it another twist. If the barrel adjuster doesn't completely solve your problem, then lubing the shifter, the derailleur pivots, and replacing cables/casings are your next steps.
    tlg
    tlg is offline
    May 2011
    Shifting fine from small cog to large, but not back down the cassette is classic cable drag. Especially if it happens after riding in the rain... with galvanized cables.
    Barrel adjusters don't just go out of wack from rain.
    But there's nothing to lose by turning a barrel adjuster to be 100% that doesn't fix it.
    My next step after that would be look for gunk in the cable guide below the BB. Rain riding tends to throw muck there.
    Probably a good idea to get stainless steel cables regardless but I'd explore free steps first before jumping to new cables if you don't want to spring for them.
    Apr 2007
    Thanks folks for the ideas. I did try turning the barrel adjuster and it didn’t help at all. After cleaning the whole bike and lubing all the pivots, no improvement. I didn’t realize the galvanized cables would cause such a problem after the storm, so it didn’t occur to me that that would be the problem. I got the stainless steel replacement cables, but now thinking I might as well get new housing as well. Not sure what the cheap cables could have done on the interior of the housing. Just as well as to re-boot and start with fresh cables and housing.
    Thanks again.
    Nov 2013
    I'm having the same problem on my bike that's a permanent fixture on my smart trainer. The rear cable was replaced recently and is unfortunately not stainless, but doesn't get exposed to weather so I'm assuming that's not causing the shift issues. I've adjusted the bajeebers out of the barrel adjuster to no avail... down shifting is still 'iffy'. I did notice my chain is badly stretched and a new one will be here Thursday, so I'm hoping that'll resolve my issue... I'll report here if it does!
    [REDACTED]
    May 2014
    If the housing has some miles on it, you may as well replace it. If less than 2K miles or so, I wouldn't bother. The galvanized cable isn't going to rip up the inside of the housing in a NY minute.
    Quote Originally Posted by PoorInRichfield View Post
    It's probably the same thing. Just worse. Rain doesn't contain salt. Dripping sweat does.
    tlg
    tlg is offline
    May 2011
    Yup. Sweat is 10x worse than rain.
    As others have posted sweat is much more of a problem than rain. Also chains don't stretch. Pins, bushings, and rollers wear...the chain gets longer but no part of it 'stretches'.
    Nov 2013
    I'm well aware of the mechanics of chain wear... no one that I know says, "I need a new chain because the physical components of the chain have loosened-up over time, giving the appearance of a longer chain that has stretched but technically didn't." That, and I'm a beast on Zwift... when I sprint, I bend metal! hehe...
    tlg
    tlg is offline
    May 2011
    Well you could just say "I did notice my chain is badly worn".
    Oct 2013
    My chain is worn?
    BANNED
    Nov 2013
    My "eXtra Stretch Proof" KMC chain arrived today and although it certainly helped make my shifting crisp, it wasn't the reason my rear derailleur wasn't down-shifting right.
    After replacing the chain, I noticed that when my chain was on the smallest cog, the rear derailleur cable was very loose because it had stretched a lot since I installed it a few months ago. So loose that adjusting the barrel adjuster couldn't compensate for the lack of tension.
    I retensioned the cable by loosening the rear derailleur bolt, pulled the cable taught, tightened the bolt, and made the final adjustments with the barrel adjuster. Now the bike shifts like new.
    Guess what else doesn't stretch...
    [REDACTED]
    May 2014
    Semantics!
    Yeah, yeah, chains don't stretch as in any parts of them stretching. But through wear, the chain gets longer, so it effectively stretches.
    Cables don't stretch as in the metal cable actually stretching. But they seat further into housings and effectively stretch.
    To the OP, if your cable needed that much of an adjustment, you may want to check under your hood to make sure it's not frayed. That is were cables wear on Shimano shifters. That will effectively make the cable longer or "stretch" it. If that is the case, it won't be long before it totally breaks.
    tlg
    tlg is offline
    May 2011
    Semantics!
    Saying it "effectively stretches" is the semantics. Stretching requires deformation of the material. There is no deformation. There error of saying chains stretch is that people actually believe that! And don't understand what's actually occurring. Once I explain that to people, it's like a light bulb goes off and they say "Oh I need to clean my chain more". No... you're not so massively strong that you're making your chain longer (yes people believe that)
    Yea but if it was frayed, it wouldn't be shifting like new after taking the slack out. But it's never a bad idea to check Shimano shifters for fraying.
    I'm still finding it odd that this just suddenly happened after riding in the rain. Now I'm wondering if the cable slipped under the anchor bolt.
    [REDACTED]
    May 2014
    Very good point. I stand corrected
    A possibility.
    Semantics!
    No, it makes it shift like crap. In both directions. Not like a cable getting 'longer' from stretching which would result in it just being 'loose'.
  1. Ultegra rear derailleur shifting problems from 16th to 17th cog
    By ericliu23 in forum Components, Wrenching
    Last Post: 03-13-2011, 02:48 PM
  2. rear shifting problems
    By andulong in forum Components, Wrenching
    Last Post: 11-18-2009, 05:05 PM
  3. Replies: 5
    Last Post: 05-15-2008, 03:00 AM
  4. rear derailleur shifting problems
    By russellhitchcock in forum Components, Wrenching
    Last Post: 07-26-2006, 06:40 PM
  5. Rear shifting problems. Is something bent?
    By pavedroad in forum Components, Wrenching
    Last Post: 03-09-2005, 05:50 PM
