Rear Wheel Grind
Results 1 to 13 of 13
    Jul 2009
    Rear Wheel Grind
    I've experience intermittent grind noise coming from my rear wheel while free wheeling.The noise stops when peddling. It's a Mavic Krysium wheel with a Campy Record cassette. About two weeks prior there was a clicking noise coming from back when riding, no noise when I checked it on bike stand. What are possible causes?
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    When is the last time you serviced your freehub? Mavic's require frequent service.
    Banned forever.....or not
    Aug 2002
    More common, is the screaming from the Mavic freehub....Clean and lube, before you have to replace.
    Dogbert.
    I>U
    Jul 2009
    Hub cleaned and lubed. Seems to have resolved the screaming. Now to figure out where the clicking is coming from.
    Oct 2013
    ah yea, you know when you lubed it, there were little thingy's in there. Well, when your riding, they click when you are not pedaling.
    BANNED
    Jul 2009
    That's not it, the click is intermittent and the noise is there whether peddling or not. I don't hear it when the bike is in the repair stand.
    Oct 2013
    When I'm riding and I go about 35mph or over, I get a knocking sound. What is it?
    I don't get it in the garage, cause I'm not going 35mph I guess.
    BANNED
    Aug 2002
    It's your heart telling you not to do that very often.
    Dogbert.
    I>U
    Feb 2002
    Quote Originally Posted by Not-So-Fast View Post
    If you get a click when coasting, it probably is at the frequency of your wheels spinning. It could be a valve stem hitting the rim, a crack in the rim, noise from where the spokes cross, a computer pickup hitting the magnet on the spokes, wheel reflectors, Presta valve nuts (throw them away).
    'brifter' is f'ing stupid
    So it happens when you're trying to sell things?
    I'd check the things that Kerry mentioned...valve stem clicking against the rim, possible spoke/rim damage. Generally Mavic Ksyrium spokes don't touch each other where they cross but it's worth a look. Are they Equipes, or Elites?
    #promechaniclife
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Intermittent clicking from Mavic wheels is a well known phenomenon. It has to do with the way the rims are made and ends joined together.
    Trying to cram the rest of my life into the rest of my life!
    Oct 2013
    I am being totally serious, what is it?
    BANNED
    Feb 2002
    Quote Originally Posted by DaveT View Post
    Man, I can't believe I forgot about that one. Pinned rim joints and possible associated bits of metal floating around inside the rim.
  1. Free Wheel Grind
    By Not-So-Fast in forum Wheels and Tires
    Last Post: 2 Weeks Ago, 07:59 AM
  2. Back to the grind...
    By JoeDaddio in forum The Lounge
    Last Post: 01-05-2009, 11:37 PM
  3. Chain grind - front derailleur adjustment
    By oyeflaco in forum Beginner's Corner
    Last Post: 05-08-2006, 12:11 PM
  4. Grind Triple Into Double Crank
    By breadrunner in forum Components, Wrenching
    Last Post: 05-24-2004, 02:22 PM
  5. new 105 cassette grind
    By greyghost in forum Components, Wrenching
    Last Post: 02-13-2004, 07:51 AM
