Rear Wheel Spacing? A 130mm in a 126 frame??
Results 1 to 2 of 2
    Reputation: cdadaa's Avatar
    Jan 2003
    Will a newer 130 rear hub work in an older bike with 126 spacing? I know I could expand the rear triangle to except the 130 but should I? I want to put a 8 or 9 speed setup on this bike. It is a Reynolds 531 steel frame?
    Thanks...Dan
    Are you a nurse, Fokker?
    Reputation: scrublover's Avatar
    Oct 2002
    Quote Originally Posted by cdadaa
    Thanks...Dan
    yeah, it'll be fine. 4mm is really pretty minimal. and the steel will handle the moving easily.
  1. Does 1 lb of fat = 1 lb of frame?
    By Bacco in forum General Cycling Discussion
    Last Post: 08-03-2004, 09:21 PM
  2. Can Shimano wireless Flight Deck be used with rear wheel?
    By Larry Klassen in forum Components, Wrenching
    Last Post: 07-04-2004, 09:07 AM
  3. Reviews of ENO Hub?
    By Gus8 in forum Fixed/Single Speed
    Last Post: 06-01-2004, 04:56 AM
  4. HELP! Fixie Conversion on a 130mm RD frame?
    By JOMAS in forum Fixed/Single Speed
    Last Post: 03-19-2004, 10:59 AM
  5. tolerances of rear wheel dishing
    By weltyed in forum Components, Wrenching
    Last Post: 02-07-2004, 06:42 PM
