removing Mavic 419 disc tire
Results 1 to 2 of 2
    Aug 2012
    I have a Cannondale Slate gravel bike. Tire was flat and I see some sidewall damage. Somehow I fixed a flat on the front wheel but I just can't get this tire off the Mavic 410 disc 650b wheel. I've changed plenty of road/mtn bike tires, but this rim is deep (what is that called?) and i can't get a hold of the edge. Any suggestions?
    Aug 2012
    I got the tire off, with struggle. Somehow I got it started with tire lever, but even then I couldn't get it going more than 1st lever, until I put a small straight screwdriver tip next to lever and even that was tough! There has to be a method and tool to this. What if I was in the woods flat 15 miles away from car?
    It was a very slow bubble hole. Hopefully tube is all good. But my other problem I see a slight gash on the sidewall, not in the area of the puncture. On the inside it looks like it goes through only a teeny bit. Could I use some tube repair glue and throw some gorilla glue over it, or would that eventually cause a rub and a flat? Or once the sidewall has even a slight gash time to say goodbye?
  1. Mavic Yskion Pro UST tire work on non-Mavic rim?
    By GFisher2001 in forum Wheels and Tires
    Last Post: 11-05-2017, 01:39 PM
  2. a "real job" vs being a 419 scammer
    By Creakyknees in forum The Lounge
    Last Post: 11-07-2011, 01:42 PM
  3. ace shifters 419
    By easyridernyc in forum Hot Deals
    Last Post: 03-08-2010, 10:44 AM
  4. 419 Spammer baited to carving a wooden C=64
    By bas in forum The Lounge
    Last Post: 06-30-2006, 04:38 PM
  5. [email protected] is 419 scammer
    By zeytin in forum Classifieds Feedback - Scam Warnings
    Last Post: 09-16-2004, 10:39 PM
