replacing a broken spoke
Results 1 to 7 of 7
    Sep 2004
    I replaced a broken spoke but the spoke that I used for replacement is a little shorter than the others. There are a few threads showing going into the nipple. Is this ok ? Or should get another spoke ?
    Reputation: JCavilia's Avatar
    Sep 2005
    It's probably okay
    How many is "a few"? If it's a problem, you'll find out when the nipple threads strip out. If they don't, it's not a problem. I wouldn't worry about it.
    Did you lube the threads? If so, I'd worry even less. If not, you could back it out a few turns, put a drop of oil on the threads, and re-true it. That will reduce the risk of problems if you have to adjust in the future.
    Sep 2004
    There's only two threads showing. I didn't lube the threads. Thanks for the reminder.
    Arrogant roadie.....
    Reputation: Dave_Stohler's Avatar
    Only 2 showing? Sounds OK to me. Now, if only 2 were engaged.......
    We are the 801
    We are the central shaft
    If I only knew...
    Jun 2006
    You can go +/- 2mm on the correct spoke length, anything more or less and you may run into problems getting the proper tension.
    Jul 2007
    somewhat related question:
    If a replacement spoke is different from the rest, say straight straight VS butted or a different gage, does the difference present any problems? Any problem mixing brands?
    If I only knew...
    Jun 2006
    Well you should really try to use the same type of spoke because different gauges and butted spokes will have different tensions associated with them, that being said I have found it not to really be that big of a deal if you have to use a straight gauge spoke in place of a butted spoke. Generally if you start to have broken spokes on a wheel then something is off with the tension or the rim could be bent slightly causing some spokes to be too tight therefore breaking often.
