Reusing pins when reconnecting/assembling 11-speed chains
Results 1 to 24 of 24
    Reputation: OldZaskar's Avatar
    Jul 2009
    I'm not talking about totally removing - as in totally out of the chain - the pin. I'm talking about pushing a pin 80% through, separating the link, then reattaching the chain by pushing that pin back home. I've been doing this forever - going back to the BMX days and thought the 7, 8, 9, 10, 11 speed evolutions.
    Rumor has it, that method of pushing that pin back to reattach the chain stopped being okay with the 10-speed chains. Something about the flair on the pin, the pin being shorter, etc.
    Was there a significant change in the design from 9 to 10-speed that changed this? Or, is it that it was always less than perfect and it reached a tipping point at the 9-10 change?
    'brifter' is a lame word.
    I would never ever do this.
    Never.
    Ever.
    What on earth could make it worthwhile?
    I work for some bike racers
    and a bunch of skateboards
    Apr 2006
    I'm thinking he's got a good dental plan now, and is interested in trying it out.
    Sent from my SM-G950W using Tapatalk
    Jul 2009
    I should add that I've moved on - I stopped removing/reattaching chains that way. Just wondering when it became such a bad idea... well, that assumes it was ever a good idea.
    Quote Originally Posted by OldZaskar View Post
    I'm thinking like you...right around the time we went to 9 speed. It always seemed to be fine w/ bmx bikes and old 6, 7, and even 8 speed chains where there was a decent amount of pin proud of the plate. That ended w/ either 9 or 10 speed, can't remember exactly when but I seem to remember the Shimano guys saying don't do this anymore.
    Oct 2014
    Yup, nope - not on an 11 speed chain.
    New pin or a quick link.
    I've experienced a chain failure (Wipperman link) and lived to tell about it. It was the second worse experience I've ever had on a bike (#1 is being hit by a car!).
    Nov 2014
    I remember it being a bad idea once Shimano went to the snap off pins last century, which I promptly ignored and after repeatedly pulling chains apart, switched to Sachs and never went back.
    Oct 2011
    I too use Wipperman chains on some bikes.
    I have not had the connex link fail while riding but have found one with a crack in it and changed it for a new one. It was an 8-speed model. Big crack from pin to edge.
    I noticed it when reconnecting after routine chain maintenance.
    I always look at them carefully now and have yet to see another one cracked.
    Going on about 10 or more years now using them on several bikes.
    Guess sometimes this kind of stuff happens. Glad you were not hurt.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Considering how cheap chain pins are, there's no reason to take the risk. Heck, there's no reason to take the risk anyway.
    And from what I understand, you should never break a chain in the same place twice. Is this true?
    Banned forever.....or not
    Aug 2002
    Rumor has it, that method of pushing that pin back to reattach the chain stopped being okay with the 10-speed chains...............................
    Actually, that method stopped when 8 speed chains started.
    Dogbert.
    I>U
    Yes, true. If you are using the Shimano pin you should go to another spot on the chain to break it.
    Jul 2009
    What's the preferred method - the Wippermann/Powerlink/Quicklink or the break-away pin?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    A quicklink is less much less hassle and lasts just as long. There's really no reason not to use one, and save yourself some time/effort.
    I prefer to use some type of link, especially if the chain is on a bike that gets overlubed or really dirty. It's just a bit easier to take the chain off for cleaning. Doesn't really matter, but that's my preference.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Yup, it was 9sp. That's when the side plates got too thin and they started making the pins flush. So you couldn't safely push the pins out and back in.
    8sp had longer pins so there was some margin for error.
    Aug 2017
    When I break my 11sp chain, a tiny 'ring' pops off the pin and is left on the punch of my chain tool. It's the flare that was on the side of the pin seated on the punch. I've broken my chain twice, and there are two rings on my chain tool. I noticed them last night; what a coincidence now I see this thread. Anyway, that's enough for me not to try to reuse them.
    Banned Sock Puppet
    May 2014
    Exactly my understanding, thanks!
    Now for the big question. Is it ever acceptable to re-use a quick link?
    Feb 2002
    With Campy, it was 10s. But the issue is the same regardless of brand: they started peening the ends of the pins to hold them in place and so reusing a pin wouldn't work.
    tlg
    tlg is offline
    May 2011
    There are some that are designated as reusable.
    Personally, I reuse them (even the non-reusable ones). I've had zero issues.
    ^This^
    Spending $10 or so to replace something free is a reason. I'm not that cheap but I'll gladly spend the extra 1 min. for $10.
    Although someone in another thread was saying Shimano now includes quick links with new chains, so maybe now there would be no reason.
    tlg
    tlg is offline
    May 2011
    Shimano pins aren't free. Topic at hand is re-using pins. If you want to split and re-connect your chain, it's $3.33 a pop.
    3 for $10.
    https://www.amazon.com/Shimano-Spare...eed+chain+pins
    6 for $14 ($1 cheaper than Shimano pins)
    https://www.amazon.com/KMC-Missing-L...ink&th=1&psc=1
    Banned Sock Puppet
    May 2014
    OK, thanks!
    Reputation: velodog's Avatar
    Sep 2007
    ^This^
    Me too.
    Too old to ride plastic
  1. Replies: 4
    Last Post: 03-01-2014, 12:32 PM
  2. Reusing SRAM PC-1 pins
    By nate in forum Fixed/Single Speed
    Last Post: 06-05-2012, 02:41 AM
  3. Replies: 13
    Last Post: 06-10-2006, 05:56 AM
  4. D/A 10 spd chains & pins ??
    By yellowspox in forum Components, Wrenching
    Last Post: 08-11-2005, 09:41 AM
  5. Reusing SRAM pins
    By filtersweep in forum Components, Wrenching
    Last Post: 05-06-2005, 06:57 AM
