RXS pedal service - clockwise or counterclockwise?
Results 1 to 6 of 6
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    I also posted in the Time forum but no one reads it?
    So I've got a lot of RXS pedals (from First to Ulteam), and typically the inboard bearings go bad and need to be replaced. The problem I have is that there seems to be no rhyme or reason as to the threading on the caps. On some the drive side pedal cap is right hand threaded, on some left. The non-drive is (I think) always right hand threaded. I've broken caps because I guessed wrong, does anyone know what to look for before trying? I can't see any thread with the cap screwed on.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    Russian Troll Farmer
    Sep 2016
    On Look pedals (which are French made), the mark threads as "D" (droit) for right-hand thread and "G" (gauche) for left-hand thread. I believe Time is also a French company.
    "L'enfer, c'est les autres"
    Matnlely Dregaend
    Jul 2006
    There are D and G marks on the pedal bodies but those only indicate the pedal side, not the thread. I can't find any markings for the thread.
    May 2011
    What tool do you use to remove the cap?
    Well, you know, that's just, like, your opinion man. - The Dude
    Matnlely Dregaend
    Jul 2006
    Quote Originally Posted by OldChipper View Post
    I use a wrench that came with titanium spindles I bought a while back. It works by threading the pedal and wrench on the crank arm, then turning the wrench.
    BTW the Ti spindles are defective and I wouldn't recommend them. They're missing the groove for the inner bearing retaining clip, and the spacers/clips that come with them don't fit inside the pedal body. I made it work by machining in the missing groove for the OEM clip in the photo.
    May 2011
    Interesting, thanks. Might be worth it to me just to get the wrench. I have a bunch of Time pedals several of which need the bearings serviced. Way cheaper than replacing them.
  1. Replies: 0
    Last Post: 10-03-2020, 08:28 PM
  2. Replies: 66
    Last Post: 10-14-2007, 02:05 PM
  3. Smugglers Notch, VT (counter clockwise)
    By PCM in forum Commuting, Touring and Ride Reports
    Last Post: 09-01-2007, 06:57 PM
  4. time RXS/RXS carbon----> price hunting
    By nairhair in forum Hot Deals
    Last Post: 04-11-2005, 11:34 PM
  5. Clockwise or Counter-Clockwise to remove Ultegra crank arm?
    By mwilcko2 in forum Components, Wrenching
    Last Post: 03-20-2005, 08:29 AM
