Is it safe to use bar-end shifters with a carbon drop bar?
Results 1 to 3 of 3
    Reputation: Grog McCog's Avatar
    Jan 2020
    The bar is the Fizik Cyrano R1 Carbon Handlebars. The bar-end shifters are Microshift (mountain-gearing compatible). They attach via internal expansion, so they presumably won't crush the bar's ends, but I worry about whether they will hold up to repeated stress induced from shifting.
    Apr 2014
    Why wouldn't you directly contact Fizik about this? No one here can safely you give an answer on this except the manufacturer. Carbon bars are reinforced in the areas that have the most stress on them. Anything that you do that may introduce stress to an area that it wasn't designed for could void your warranty.
    Jan 2020
    Thanks very much.
    This forum is quite a valuable information resource.
  1. SRAM bar end end shifters on downtube?
    By e39540is in forum Components, Wrenching
    Last Post: 10-17-2010, 08:23 AM
  2. Cutting drop bars for bar end shifters
    By clarinetcola in forum Components, Wrenching
    Last Post: 02-14-2010, 01:06 PM
  3. How to install bar end shifters on a drop bar?
    By matchmaker in forum Components, Wrenching
    Last Post: 08-26-2009, 03:28 PM
  4. First Group Ride = Drop Drop Drop
    By Darin in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-18-2009, 08:16 PM
  5. crack in carbon drop bar, is it safe?
    By jiggs in forum General Cycling Discussion
    Last Post: 07-26-2008, 06:32 PM
