Screw holding seat in place is loosening quickly
Results 1 to 4 of 4
    Mar 2012
    This is the second time my seat came loose during a ride. Brand new seatpost. Cannondale carbon seat save seatpost. Any ideas how to fix?
    I took some pics of the screw. Are rounded tops normal?
    Attached Thumbnails Attached Thumbnails Screw holding seat in place is loosening quickly-20190419_152826.jpg   Screw holding seat in place is loosening quickly-20190419_152910.jpg   Screw holding seat in place is loosening quickly-20190419_153637.jpg
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by sheepherder View Post
    Had the same problem on my Save seatpost. A drop of loctite on the bolt is the cure.
    'brifter' is a lame word.
    If fasteners are tightened properly they rarely loosen up. Loctite will probably help, make sure you're tightening it enough, and even front-to-back.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Are you greasing the threads? With greased threads and proper torque, the screw will very likely stay tight. If it doesn't, there might be something else going on.
  1. Trek/Bontragger carbon seat mast- seat clamp keeps loosening???
    By Upnorth in forum Components, Wrenching
    Last Post: 08-28-2014, 02:05 PM
  2. Front brake adjustment screw loosening: loctite?
    By bike981 in forum Components, Wrenching
    Last Post: 08-05-2013, 01:47 PM
  3. Size of screw holding Garmin's GSC10 speed sensor arm
    By z3phrn in forum Components, Wrenching
    Last Post: 07-11-2011, 03:39 PM
  4. Drop Outs/Quick Release Not Holding Rear Wheel In Place
    By thevalvesource in forum Components, Wrenching
    Last Post: 05-16-2009, 08:57 PM
  5. Help, Skewers not holding wheel in place
    By heatstroke in forum Components, Wrenching
    Last Post: 09-03-2004, 08:22 PM
