Screw is stuck
Results 1 to 3 of 3
Thread: Screw is stuck
    Mar 2019
    Screw is stuck
    Hi,
    I'm changing the brake pads on my bike and I've used the wrong screwdriver by mistake and I've stripped the head of the screw. How can I get it out without buying an expensive tool?
    Matt
    Feb 2002
    Quote Originally Posted by Matt.T View Post
    Hi,
    Standard first step is to file a notch in it so that you can use a flat-blade screwdriver. Next step, though difficult would be to drill it and use an Easy-Out. Not an expensive tool, but not an easy job either because the screw is likely quite small.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Drill it out.
    Try the rubber band trick
    Use a saw/dremmel to slot the head for a screw driver
    EZ Out screw extractor
  1. Adjusting Campagnolo rear derailleur - no B screw or H screw
    By Glyndwr in forum Components, Wrenching
    Last Post: 03-04-2016, 05:42 AM
  2. Master Link Stuck...very stuck
    By whatthefunk in forum Components, Wrenching
    Last Post: 10-23-2012, 09:57 AM
  3. Derailleurs: Limit Screw and B-Screw adjustments
    By RyKnocks in forum Components, Wrenching
    Last Post: 04-13-2012, 05:41 PM
  4. Help Removing Stuck Dropout Screw
    By DHallerman in forum Components, Wrenching
    Last Post: 02-20-2011, 01:37 PM
  5. Stuck water bottle cage screw
    By BikeRider in forum Components, Wrenching
    Last Post: 03-31-2004, 01:25 PM
