seatpost clamp for carbon?
Results 1 to 3 of 3
    Jan 2009
    Do I need angled seatclamp (where ends join) to protect carbon seatpost? I think I have used non-angled without problem. Is there a big difference in damage to the carbon seatpost?
    Reputation: looigi's Avatar
    Nov 2010
    Is there a slot in the seat tube of the frame to facilitate clamping of the seat post? Some frame manufacturers specify that the slot in the clamp be positioned 180 degrees from the slot in the tube to help prevent crushing carbon seatposts. If this is the case, then angled or straight shouldn't matter.
    Reputation: nightfend's Avatar
    Mar 2009
    Be sure and use carbon paste when you install the seatpost (not grease), and don't over tighten. Stick with about 6nm of force and you should be fine no matter the clamping device.
  1. R3 seatpost clamp failure and seatpost damage
    By skygodmatt in forum Cervelo
    Last Post: 12-04-2011, 03:16 PM
  2. Seatpost Top Clamp
    By 3MC in forum Campagnolo
    Last Post: 07-25-2009, 12:27 PM
  3. seatpost clamp
    By Naldayin in forum Components, Wrenching
    Last Post: 10-06-2008, 09:42 AM
  4. Saddle clamp twisting on Carbon Seatpost
    By Geet in forum Components, Wrenching
    Last Post: 01-26-2006, 09:19 AM
  5. Replies: 2
    Last Post: 12-28-2004, 09:29 AM
