Seatpost to Seat Rails Torque Specs
Results 1 to 4 of 4
    Nov 2014
    Anyone have tightening torque spec for the rail binder on a 1 bolt Chorus seatpost? Early 2000s, the sexy flattened style.
    I found a Campy manual for a 2011 carbon model which probably uses the same head, but they also said the one bolt was not supposed to be lubed.
    Dec 2006
    Answer: 13-16 Ft-lbs.
    And yes, that's for a single bolt attachment.
    Nov 2014
    Thanks, Pete.
    I ended up going in that range. Used 160 in lbs. as the Campy manual I found from 2011 called for a min of 159 and a max of 196 in lbs. Still wondering about the instruction to "never lubricate the fixing screw".
    Oct 2013
    If you lube the threads, you need to reduce the torque rating applied to tighten. The torque specs are with unlubed threads.
    Probably not going to make much difference on this bolt, cylinder heads or main rod bolts it's going to make a world of difference.
    BANNED
  1. Seatpost adapter to fit rails on modern MB/Road seat
    By shanabit in forum Components, Wrenching
    Last Post: 08-29-2016, 11:02 AM
  2. Deda Superleggero RS Seatpost - Torque Specs? Weight Limit?
    By turbomatic73 in forum Components, Wrenching
    Last Post: 09-06-2015, 05:00 PM
  3. carbon rails vs. titanium rails
    By dwl in forum Components, Wrenching
    Last Post: 08-25-2013, 09:19 AM
  4. 585 Seat Post Clamp Torque Specs
    By benolium in forum Look
    Last Post: 04-28-2008, 12:16 PM
  5. Fizik Aliante: carbon rails vs ti rails?
    By alibaba93 in forum Components, Wrenching
    Last Post: 05-18-2005, 06:17 AM
