Shifter hard to move
Results 1 to 25 of 30
    Aug 2018
    My left shifter, brand new, is very hard to move. You practically need two hands to shift the front derailleur. Any ideas?
    'brifter' is a lame word.
    You're gonna ask this and not provide any info about brand/model?
    I work for some bike racers
    and a bunch of skateboards
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Shifter make and model? Bike make, model and year?
    Is the bike new or just the shifter new?
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Quote Originally Posted by coondogger View Post
    Assuming it does shift, albeit with difficulty, here are my ideas:
    *Cable somehow misrouted through the shifter body (though without knowing the make and model of the shifter, I can't say if this is mechanically possible to do and still retain shift capability)
    *Cable constricted/impinged in its travel path (e.g., a cable binding against a stop)--though this isn't normally a "two hands" level of resistance
    *Cable frayed (possibly damaged during installation), so that bits of frayed cable prevent smooth cable travel
    *Shifter pivoting mechanism misassembled, damaged, or otherwise compromised, so that cable binds during shifting
    *Front derailleur isn't well-lubricated, or is damaged/impeded, so that cable shifts aren't enough force to move the mechanism
    It would help if you could further describe the situation. I'm assuming that the shifter is mounted on a bike, and that it's not an electronic system, but make, model, etc. would be useful for diagnostic purposes.
    Also, have you tried to shift the derailleur by simply pulling on the exposed cable along the left side of the downtube (basically, bypassing the shifter)? If it shifts properly, then the problem is "upstream," almost certainly in the body mechanism.
    Donald Trump has never had a wife he didn't cheat on.
    "Oh my god. This is terrible. This is the end of my presidency. I’m f—d.”
    Take the cable out. I assume you can figure out what how easy or hard it is to move then will tell you.
    Reputation: velodog's Avatar
    Sep 2007
    Is this the right forum for a question this "General"?
    Too old to ride plastic
    Sep 2007
    Not to worry, the OP posted the same problem in the General forum too.
    Aug 2018
    Shimano shifter. Recently installed on my 2019 emonda 5. Groupo is ultegra. The small shifter works; moves easily and derailleur responds smoothly to move chain to smaller ring. Large lever is very difficult to move, although once budged it actuates the derailleur without problems. The shifter is new because the original one broke and was replaced under warranty. That was several weeks ago.
    Oct 2013
    I see new cables in your future~!
    BANNED
    Aug 2018
    So do I. Teflon, to be exact. But they don’t change a thing.
    Sep 2011
    I'd like to see a photo of how the cable is fixed to the derailleur. It kinda sounds like it may be set up wrong.
    Quote Originally Posted by 202cycle View Post
    I'm thinking this might be the problem. But this is a new R8000 derailleur?
    Aug 2018
    Not set up wrong. Been double checked. One other thing. The lever starts off reasonably easy, then becomes very hard to push the rest of the way. Like a bow that stacks.
    So the shop that installed it hasn't had a moment and called Shimano? If they're sure it's set up correctly and won't work why haven't they taken the initiative and gotten in touch w/ Shimano?
    I'd undo the cable from the derailleur and put tension on it while holding it in my fingers. Actuate the shifter and see what it feels like. If it's smooth and pulls/releases properly you can eliminate the shifter from the problem. Check the cable routing next. There are all sorts of things that be done improperly, it's impossible to diagnose them all via the interwebs. Sounds like your shop isn't the most competent.
    Russian Troll Farmer
    Sep 2016
    OK, let's do a "root cause analysis". We have 2 options here:
    1) The unit was installed incorrectly
    2) the unit is defective
    If #1 is the case, we have 2 options:
    a) If you installed it, take everything apart, and find what you did wrong
    b) If the bike store installed it, they should do the same
    If #2 is the case, then whomever sold it to you needs to replace it.
    BTW, if the bike shop installed it and sold it to you, it's their problem. If they either can't or won't make it right, it's time to find a better shop. FWIW, my experience with bike shops is that probably 2/3 of the people they hire to repair bikes are unqualified and or incompetent.
    "L'enfer, c'est les autres"
    Aug 2018
    Eliminate installed incorrectly. The bike shop didn't install it; a former engineer who is now a bike mechanic installed it. He used to be a mechanic with the largest Trek dealership in Wisconsin.
    Aug 2018
    The new shifter is still stiff, but at least moves.
    Jan 2014
    These threads boggle my mind. The OP starts a thread by saying, 1) this thing on my bike does NOT work, and 2) so far no one can figure out why, so 3) please help me figure out what’s wrong, BUT 4) do not under any circumstances suggest that the installation was incorrect!
    Somehow the OP, who doesn’t know what’s wrong, just knows with 100% certitude that there is nothing wrong with the installation.
    It is HORRIBLE HORRIBLE logic.
    Sep 2007
    A guy who used to be an engineer before he used to be a bike mechanic?
    What does he do now, mow lawns?
    None of this matters. If the guy was an engineer he's still an engineer. Because he worked at the largest Trek dealer in WI means absolute dick.
    Apr 2006
    Engineer does not equal bike mechanic does not equal competency, and btw the most "redo" work I do on new bikes are treks. Cycling in Canada and Wisconsin is a half year outdoor sport, which doesn't attract the best talent to bike stores. My bet is on the install.
    Sent from my SM-G950W using Tapatalk
    Sep 2007
    engineer?
    Oct 2013
    hEy... I'm a n engineer & my bike is shifting fine!
    BANNED
    Banned Sock Puppet
    May 2014
    There are those who know theory and there are those who know practice. They aren't necessarily mutually exclusive, but I have known some engineers who are totally ham fisted.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Could it be FD vertical position is wrong such that when trying to shift up the chain is getting mashed up against the large chainring in a bad way?
  1. Bike struggles to move (ok, I struggle to move anymore) ??
    By jdlongstreet in forum General Cycling Discussion
    Last Post: 09-08-2014, 03:11 AM
  2. good move or bad move
    By mitong in forum Cannondale
    Last Post: 11-18-2009, 11:27 PM
  3. Centaur FD Shifter Lever Hard to Move
    By Milanomike in forum Campagnolo
    Last Post: 07-22-2008, 03:18 PM
  4. Pushing too hard or not pushing hard enough?
    By MCF in forum Racing, Training, Nutrition, Triathlons
    Last Post: 06-10-2008, 07:56 AM
  5. Replies: 14
    Last Post: 09-07-2006, 12:10 PM
