Which shifting cable housing end cap to use (metal or plastic)?
Results 1 to 23 of 23
    Oct 2009
    Does it make much difference in the shifting quality or longevity if I use the metal or plastic shifting cable housing end caps, I have bought a roll of cable housing and was needing some end caps to go with it. Thanks or any opinions.
    Apr 2014
    You're overthinking this. As long as it fits your needs, what does it really matter if its metal or plastic? All it really does is act as a seal to prevent dirt contamination.
    'brifter' is a lame word.
    I definitely prefer the metal shift ferrules, I usually use the SRAM ones. I don't like sealed ferrules, they always seem draggy to me and I like to replace my cables and housing on a regular basis so I'm not that worried about dirt getting inside the housing. The metal ferrules are stronger so they don't get bent/deformed like the plastic ferrules. The only downside is they can get a little noisy when the housing compresses and the wires start to poke out the end.
    I work for some bike racers
    and a bunch of skateboards
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I must plead ignorance here, but until now, never knew metal shift ferrules existed. Awhile back, I looked for some, but came up empty and it was then I concluded that brake ferrules were metal and shift ferrules were plastic.
    I search again today and come up with this:
    https://tinyurl.com/qotekq3
    https://www.amazon.com/Lixada-Alumin...H29?th=1&psc=1
    I learn something new every day!
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Nov 2002
    I'd use plastic ones over steel ones that can rust/corrode.
    Feb 2002
    See: Campagnolo. Metal end caps since pretty much the dawn of time.
    Banned Sock Puppet
    May 2014
    Sorry, I don't travel in those elite circles. I'm just a lowly Shimano/SRAM commoner.
    "With
    -- DCGriz, RBR.
    Are you serious? I suppose they could but if rust/corrosion is really a concern shifting ferrules is about the last place I'd worry about it. Even the most carboned out bike is going to have a lot of metal that plays a much more important role than ferrules.
    Oct 2009
    I wouldn't think corrosion would be a real concern as they are aluminum
    https://www.ebay.com/itm/Shimano-ST-...97.m4902.l9144
    Quote Originally Posted by Ventura Roubaix View Post
    Not all of them are aluminum. Some are chrome plated brass.
    Banned Sock Puppet
    May 2014
    Newflash: Aluminum DOES rust......ahem......excuse me, corrode:
    "With
    -- DCGriz, RBR.
    Oct 2009
    Sorry Guys for the incomplete thought. Yes aluminum will corrode, but my thought was, not a (real big concern). I guess if you lived near the ocean, or if they were left on for a long time it might be.
    If it was a real concern, you wouldn't be able to use the bike anyway because the hub, spokes, cassette, maybe rims, shifter internals, all screws, and on and on would all be corroded and housing end caps would be the least of your worries.
    Banned Sock Puppet
    May 2014
    Yours and Jay's points are taken. I just had to dispel the false statement that aluminum doesn't corrode.
    I have in fact seen aluminum rims that were severely pitted due to corrosion.
    "With
    -- DCGriz, RBR.
    Nov 2002
    I have steel ferrules on the rear brake cable on my '05 Trek Madone carbon bike and the front one badly corroded in the cable stop under the top tube. I suppose aluminum may have corroded too, but aluminum is much more corrosion resistant than steel (except stainless steel).
    Bottom of the top tube you say? Aluminum definitely would have corroded there too. That's the classic spot where you have to use a hammer and a screwdriver to punch the stuck ferrule out.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    I was always partial to the Wheels Manufacturing brass ones. Havenít seen them in a while, though.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Quote Originally Posted by rideit View Post
    Still available, eBay is one source.
    Trying to cram the rest of my life into the rest of my life!
    okay I guess I'll stand corrected.
    I've been using the same ones since forever. They are silver so obviously metal but to be honest I have no idea if they are steel or alloy.
    Banned Sock Puppet
    May 2014
    Do you have a magnet?
    "With
    -- DCGriz, RBR.
    No I don't have a magnet. Nor to I have any interest in finding out if my housing end caps are alloy of steel.
    Banned Sock Puppet
    May 2014
    Oh come one Jay! You gotta find out! The suspense is killing me!
    "With
    -- DCGriz, RBR.
    Feb 2005
    Quote Originally Posted by DaveT View Post
    Yup, in QBP too.
  1. Can you use a shifter cable housing as a brake housing?
    By bmwjoe in forum Components, Wrenching
    Last Post: 04-07-2013, 11:42 AM
  2. Replies: 8
    Last Post: 07-26-2012, 10:05 AM
  3. Metal vs Plastic (Derailleur) Ferrules
    By meeshu in forum Components, Wrenching
    Last Post: 07-07-2011, 04:57 AM
  4. Plastic over metal...
    By 2ndGen in forum General Cycling Discussion
    Last Post: 08-03-2009, 07:25 AM
  5. Brake Cable Sheath Metal Nipple Goes On Which End?
    By TomBrooklyn in forum Components, Wrenching
    Last Post: 07-18-2008, 07:21 AM
