Shifting Housing Failure
Results 1 to 18 of 18
    Apr 2002
    I never even took the bike on the road. I just had it on the work stand and worked on it. This was new housing for the front shifter.
    Sep 2011
    You used a brake ferrule (and a crappy one at that). Shift housing needs shift ferrules, they are reinforced at the end to keep that from happening.
    'brifter' is f'ing stupid
    I'm not sure that's a brake ferrule as it seems to fit the housing pretty well...unless it's 5.0mm shift housing. The brake ferrule hole is about .5mm larger than the shift ferrule hole, that could lead to the wires poking out. The shift ferrules that most people use are plastic and they hold up. I'd also make sure the end of the housing is as square as possible when cut. I don't finish them on the grinder but just make sure it's as square as you can make it.
    #promechaniclife
    Oct 2013
    That's not shift housing failure, that is mechanics failure. Just cut those wires off square and put a shifting end housing on it.
    BANNED
    Sep 2011
    5mm shift housing and the cheep brake ferrule for sure. My boss used to insist on using 5mm shift housing Then he went cheep and ordered those crappy ferrules. The OP photo is exactly what happens when you use that combo.
    Apr 2002
    It is 4mm shifter housing for sure, and a 4mm ferrule. I don't think that brake ferrules come 4mm. Any suggestion what I can improve on to avoid this happening again.
    Oct 2013
    If you initially cut them off square, tight bends could cause that. Maybe install the cable first then cut off square after you got most of the bends worked in?
    BANNED
    Sep 2011
    Quote Originally Posted by daniell View Post
    That is not a 4mm ferrule, it is a cheap 5mm brake ferrule. There is no 4mm ferrule that looks like that.
    Apr 2002
    Quote Originally Posted by 202cycle View Post
    Check image!
    Dec 2006
    Something doesn't look right with the ferrule in the photo-is the cable exit hole flared or is that the liner from the housing poking through the hole?
    I'm inclined to think the ferrule was cheap or out of spec., with an oversized exit hole or too thin, resulting in a flared end from shifting pressures. Also, the ferrule doesn't have a squared-off end such as seen on Jagwire cables, which I think have more material around the exit hole.
    Apr 2002
    Quote Originally Posted by Peter P. View Post
    These are 4mm aluminum ferrules. I would think that they would be better than plastic ones.
    Apr 2002
    I think that I may have found the problem. Though the aluminum ferrule is 4mm, the exit hole is too large. I compared it to a plastic one. That goes for both shifter and 5mm brake ferrules.
    Dec 2006
    What do I win?
    Seriously, I've never had such problems with Jagwire cable kits. Worth trying their ferrules.
    Apr 2002
    I am wondering whether I should also change the ferrules on the brake housing. The inners are wound horizontally thus making it less likely to come through the ferrule.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    If it ain't broken...................
    "With
    -- DCGriz, RBR.
    They chromed brass, not aluminum.
    No need because of the way they're made and the brake cable is larger and fills the hole more completely.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    They're chromed brass, not aluminum.
    Fixed.
    "With
    -- DCGriz, RBR.
    Oct 2013
    Oh no, you didn'[email protected]
    BANNED
  1. Trek not liable for failure to warn of carbon fiber failure
    By RichardT in forum General Cycling Discussion
    Last Post: 03-21-2015, 05:56 PM
  2. Can you use a shifter cable housing as a brake housing?
    By bmwjoe in forum Components, Wrenching
    Last Post: 04-07-2013, 11:42 AM
  3. Frackin Hard Drives. . .Failure on Failure
    By Ridgetop in forum The Lounge
    Last Post: 05-21-2010, 09:46 AM
  4. Internal Brake Housing...Cable Housing....
    By spepic in forum Components, Wrenching
    Last Post: 07-14-2008, 05:40 PM
  5. Brakecable Housing and cable failure?
    By joesoap in forum Components, Wrenching
    Last Post: 08-22-2005, 07:03 PM
