Shim Dura Ace non-drive side crank
Results 1 to 6 of 6
    Feb 2013
    Is it feasible to shim the non drive side crank out a mm or 2? Have a 4iiii power meter from another bike I want to put on new Trek Domane and the left side pod kisses the down tube. I realize there is a stopper pin there but I believe it can still move some. Any ill effect from doing this? I realize my Q factor will change but not concerned with that. Do not want to do anything to hurt bottom bracket.
    'brifter' is a lame word.
    Not a good idea. You want full engagement w/ the crank axle. You want the stopper pin doing it's job. You won't hurt the bottom bracket but you're more likely to screw up the NDS crank arm...and/or crash.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2013
    If I can gain enough clearance with stopper still engaged would that be okay?
    I would not shim a Shimano Hollowtech crank ever. Sorry, but that's one thing I won't mess with. How much room do you need to get the power meter to clear?
    Sep 2011
    +1 on that. Never, ever. The pinch bolt would move out on the spindle creating a force that was never intended. You could put too much pressure on the end of the spindle and potentially ruin not just the left arm, but the whole crankset.
    Feb 2013
    It is just kissing it. Realistically probably need 2mm. Will take your advice and not do it. I can buy another left crank fairly cheap and have another pod installed or just use the right side.
    Thanks for your help.
  1. Dura-Ace 7900 non-drive side crank hangs over the axle. Normal?
    By Waspinator in forum General Cycling Discussion
    Last Post: 07-28-2013, 05:57 PM
  2. crank non drive side help
    By spoon243 in forum General Cycling Discussion
    Last Post: 03-16-2012, 08:20 PM
  3. Replies: 8
    Last Post: 06-25-2009, 09:32 AM
  4. Need help installing non-drive side crank arm. Thanks!
    By MONsterD in forum Components, Wrenching
    Last Post: 04-24-2008, 05:07 PM
  5. Drive-side Hub Bearings Dirty, Non-Drive Side Clean
    By lml1x in forum Components, Wrenching
    Last Post: 02-19-2008, 07:34 PM
