Shimano 10 speed cassette spacer
Results 1 to 5 of 5
    Oct 2010
    I know when using Shimano 10 speed cassette on Shimano hubs, you put the included 1mm spacer behind.
    How do I know if I need it for other brand wheels or generic "Shimano/SRAM compatiable" freehubs?
    Reputation: Optimus's Avatar
    Jun 2010
    Normally if you're using a shimano 10 speed cassette, you'll need the spacer regardless of the freehub manufacturer!
    "Those who like it, like it A LOT!"
    Oct 2010
    Thanks!!
    Banned forever.....or not
    Aug 2002
    I think that you need it on every hub except the "old" 7800 DA hub that was made for 10 speed only.
    (how often does Shimano really blow things?)
    Dogbert.
    I>U
    Jan 2009
    Instead of memorizing rules and exceptions or or depending on the advice of others, you can know how to decide for yourself.
    For the lockring to work as designed the first sprocket of the cassette must overhang the freehub body slightly. This allows the lockring to compress the cassette before bottoming out against the freehub. It's analogous to how the stack height of the stem and spacers must be taller than the fork for threadless headsets.
    Add or don't add spacers such that the front sprocket overhangs by about 1mm and you'll always be right.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
  1. 11-speed Cassette Spacer Issue
    By iridepinarello in forum Campagnolo
    Last Post: 06-16-2010, 07:46 PM
  2. 10 speed cassette spacer question
    By cyclust in forum Campagnolo
    Last Post: 03-02-2010, 01:44 PM
  3. Do you need the spacer for Shimano 10 speed cassette?
    By primalcarl in forum Components, Wrenching
    Last Post: 04-22-2007, 11:21 AM
  4. Shimano 10 speed cassette spacer
    By dazman in forum Shimano
    Last Post: 02-04-2007, 07:08 PM
  5. AC 350 shimano cassette spacer-yes or no
    By Shane in forum Components, Wrenching
    Last Post: 08-04-2004, 11:43 PM
