Results 1 to 25 of 28
    Nov 2002
    Shimano 105 vs. Ultegra
    I'm looking at a bike that costs $800 more with Ultegra components than 105 (it has disc brakes). How much better is Ultegra?
    'brifter' is a lame word.
    As Kerry asks...how long is a piece of string? No way to answer that question.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2002
    Would you spend the extra $800 for Ultegra?
    Which bikes are they? Many times the frame will also be upgraded. With Trek it's really hard to make this comparison because the it's not only a 105 to Ultegra upgrade.
    Dec 2006
    You will not see $800 worth of speed increase.
    Buy it if you can afford it, otherwise don't lose sleep over your choice. The most obvious, easy to advertise benefit is less weight, but that is minimal in the overall scheme.
    Reputation: velodog's Avatar
    Sep 2007
    What's the pocket book say?
    Too old to ride plastic
    Nov 2002
    Orbea Gain M20 vs. M30. Same frame and wheels. The only difference is the stem and bars plus Ultegra vs. 105.
    Jun 2004
    You wonít likely see any improvement in shifting or brake performance. With the 105 5800 group, Shimano seemed to have hit the sweet spot with price vs. performance. The 7000 group only got better. Iíve used Ultegra for 20+ years, built my last with 5800. It is terrific.
    Nov 2002
    Quote Originally Posted by Steve B. View Post
    Thanks for that. My past bikes have been Ultegra also. I added up the weight and I'd save only about 0.33 pounds of weight with Ultegra. I could put that $800 saved towards other things.
    I was interested in what CX would say about the mechanics of the two groups since he works on them. Are there differences in pivot bearings, longevity?
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    I've ridden them both. Currently on Ultegra 6800. There is no difference in performance other than weight. Ultegra is lighter and so is your wallet. Save the $800 and put that into better wheels.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Nov 2013
    Quote Originally Posted by frdfandc View Post
    Both bikes have hydraulic disc brakes? If so, I'd agree with the frdfandc... you probably won't gain much by going Ultegra so save the cash for other upgrades or needs.
    *** Edit ***
    Better yet, take that $800 and buy a smart trainer and get on Zwift or some other online riding site. It'll help you to stay in-shape all year long regardless of the weather. You're welcome.
    Reputation: GlobalGuy's Avatar
    Jun 2015
    IMO if one takes emotion out of the decision its a no brainer--go with the 105. The biggest one level egregious difference in price of the entire Shimano drivetrains is the 105 and Ultetegra. Most serious experienced riders can't tell the difference based upon shifting between the two.
    If you have somewhere you could wisely spend the $800.00 go for the 105. As the others have posted it's very close to Ultegra in performance and weight. I haven't experienced any differences in the areas you mentioned. If braking performance is at all an issue I might upgrade the rotors to Ultegra, but that's about it. That would still leave you a bunch of $$$ to upgrade the wheels if you want to. 105 is great stuff.
    Nov 2002
    Thanks all. I bought the bike with 105.
    Nov 2013
    Quote Originally Posted by PoorInRichfield View Post
    Yes! Let's see the new bike!
    Nov 2002
    Nov 2013
    Same color as my Trek Domane... "Model T Ford any color as long as it's black" black
    I'd be shocked if that was the entire story. I'd guess they have different wheels and who knows what else also.
    Nov 2002
    I compared the two bikes' spec sheets side by side on the Orbea website. Everything was the same except the stem and bar. Same wheels, tires, saddle, frame, etc.
    The tires are tubeless but tubes were installed. I think the rim tape/strip is tubeless also, as it's a blue translucent plastic, but don't know. Is the Mavic tubeless rim strip that color?
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    It's an eBike. At 28lbs, weight is irrelevant. Go with 105.
    Sep 2007
    I didn't realize that till your post, and no I'm wondering why a compact crank.
    tlg
    tlg is offline
    May 2011
    To get it up hills if the battery dies?
    Nov 2002
    Yes, probably right. I took the bike out for a hilly 25 mile ride and used up more than half the battery, so unless I use it more sparingly on a longer ride, I might run out of juice. They're supposed to be coming out with a bottle battery that doubles the battery capacity. I'll probably buy it.
    My first ride on road disc brakes. Pretty nice but I expected more power, frankly. 160mm rotors front and back too. Seemed on par with my rim brake bike with Kool Stop pads. The levers go almost all the way to the bar. Any way to have less brake lever stroke? I was looking for a free stroke adjustment but couldn't find it (read the Shimano manual), probably doesn't have one.
    Rub it............
    Nov 2007
    If they are the Aksium UST Disc, then no tape is needed. If it has tape, then the wheels are not tubeless, because Mavic only does UST where no tape is needed.
  1. Upgrading 105 to Ultegra: can I keep my 105 brakes?
    By ebtromba in forum Components, Wrenching
    Last Post: 06-24-2014, 05:20 PM
  2. Shimano 105 components upgrading to shimano ultegra 6800?
    By Enrique in forum Bikes, Frames and Forks
    Last Post: 05-23-2014, 08:25 AM
  3. Replies: 20
    Last Post: 06-21-2011, 08:24 PM
  4. Shimano 105 vs. Shimano Ultegra
    By [schmick] in forum Components, Wrenching
    Last Post: 09-04-2004, 10:47 PM
  5. Shimano 105 double cranks w/ 105 triple rear derailleur?
    By Bike junkie in forum Components, Wrenching
    Last Post: 07-13-2004, 07:46 PM
