Shimano 7700/7701 Dura Ace Bottom Bracket
Results 1 to 6 of 6
    Reputation: bikejr's Avatar
    Jul 2004
    I just installed a Shimano Dura Ace 7701 bottom bracket with a new crank. It said 7701 on the bottom bracket but the directions are for a 7700. Not sure that's all about but at any rate I put the left hand lock ring on how they say to remove the play but not too tight etc and once all installed Inotice maybe a mm or so of threads are still showing towards the crank arm. I suspect I need some kind of spacer or something up against the frame to make the lockring flush so that no threads stick out. What are these "spacers" called and where might one get them or does it really matter if the threads stick out a little.
    Windrider (Stubborn)
    Reputation: Len J's Avatar
    Sounds to me like.....
    Quote Originally Posted by bikejr
    you didn't tighten the drive side enough.
    The Drive side should be flush with the BB. If you have the right spindle length, the BB is dsigned to provide the correct chain line when flush with the BB.
    Once that is right, you then install the non-drive side. You know it is right when after you install the lockring, there are little if any teeth showing on the non-drive side.
    My .02
    Len
    "Evil....is the complete lack of Empathy!"
    ""We are what we repeatedly do. Excellence, then, is not an act but a habit. " Aristotle
    No one is as bad as the worst thing they have done & no one is as good as the best thing they have done.........think of that when you feel like you understand someone.
    Jul 2004
    Quote Originally Posted by Len J
    My .02
    Len
    I installed the drive side first, which is of course the fixed part. I tightened it until it was up against the frame and snug as I could get it with the lame three pronged tool to install (there are no spines to use the regular BB nut to tighten it). Not sure how it would tighten anymore. The left side is backed off 1/16 of a turn as they suggested. If I tighten that up (which would bring the threads at least further in the shell, then the spindle binds. It is a 68mm bottom bracket (or at least that's how it is labeled) and my frame has standard size tubes.
    Sep 2002
    You are OK... Threads showing on the left side is normal.
    Install drive side. Go ahead and install drive side crank arm.
    Install non-drive side. Tighten just till "play" is gone. Use the drive side crank to feel for lateral play.
    Then tighten the lock ring.
    There WILL be threads showing off the non-drive side. Like, 2-3 mm of threads.
    Jul 2004
    Quote Originally Posted by ekdave
    Thanks for the reply.
    That was exactly how I installed it, and was the conclusion I was coming to as it seems to be working flawlessly at this point anyway and it has been run through a stomping hard hill climb, and a fast group ride with no difficulties. The exposed threads (yea like 2mm I'd say) were just somewhat of a concern.
    Banned forever.....or not
    Aug 2002
    Normal, I think that I have two threads showing on the non-drive side.
    Dogbert.
    I>U
  1. bottom bracket washers
    By freewayflayer in forum Components, Wrenching
    Last Post: 04-16-2014, 07:06 PM
  2. Dura Ace WH-7801-SL tubeless wheels
    By AZroad in forum Wheels and Tires
    Last Post: 09-08-2005, 04:22 AM
  3. Shimano Dura Ace SPD SL Pedals $85
    By Mudman in forum Hot Deals
    Last Post: 12-01-2004, 01:32 PM
  4. Record or Dura Ace?
    By WAZCO in forum Components, Wrenching
    Last Post: 11-09-2004, 10:47 PM
  5. Creaky bottom bracket? Loctite? Plumbers tape?
    By mtbcyclist in forum Components, Wrenching
    Last Post: 04-21-2004, 05:22 AM
