Shimano BBR-60 Bottom Bracket Groan
Results 1 to 14 of 14
    Nov 2014
    Just developed a "groan" from the NDS and believe it to be my threaded BBR-60 BB.
    I pulled the cranks hoping there was a place I could inject some grease, then re-torque, but there's nowhere readily appararent.
    Is my only choice to remove the threaded cups and grease from inside them? Haven't heard of a threaded BB "groaning" like this.
    thx,
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    No BB has a place to 'inject' grease.
    Grease the threads. Put it back in. If it still groans, but in a new BB. It's a <$20 BB.
    Nov 2014
    I agree on the $20 BB. Sometimes there's a way to lift a seal and inject some grease. Believe some of the Colnago BBs allow this.
    tlg
    tlg is online now
    May 2011
    Quote Originally Posted by GKSki View Post
    The BBR-60 is just a threaded Alum hub with regular sealed bearings pressed in. You 'could' lift the seals and inject grease. But I guarantee, your groan isn't coming from inside the bearing. If it were, they're completely shot.
    If the groan isn't coming from the threads, it's coming from the Alum hub/bearing interface. You 'could' press out the bearings, grease the hub, and press them back in. Hoping you don't damage them. A big wast of time for a $20 BB
    'brifter' is f'ing stupid
    When did Colnago start making bottom brackets?
    #promechaniclife
    Nov 2014
    Not sure what they are using with that new BB standard they have, but the seals were more easily pried off and replaced. When I look at the Shimano BBR-60 it looks like prying off the seals could ruin it.
    Pulled both sides, greased and torqued. We'll see and as TLG states, other than that, easiest to just drop $20 on a new Ultegra BB.
    Sep 2011
    Yeah, this is a non-service item, wear it out, chuck and replace.
    Sep 2007
    Other than perhaps very old Phil Wood BB's, I'm unaware of any BB per se that has grease injection options. There have been some frame makers that have included grease ports on the BB shells and there have been a few kits over the years to allow grease injection into many/most types of BB's - again going through the BB shell. Grease injection ports on turn of the century bikes, with one piece cranks were very common. Such systems made a little more sense for off-road bikes and touring bikes that are subjected to lots of grit and water intrusion, or when using very pricey and difficult to service BB's. I've used grease injection for BB's on old Merlin's, and though quick and easy, it is pretty darn messy. For a BB that only costs $20 and 10 minutes time to replace, I'd just replace the darn thing.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    A $17 BB to be exact:
    https://www.jensonusa.com/Shimano-BB...Bottom-Bracket
    Not in the pic where it says "sealed cartridge unit" as in cannot insert grease.
    As others have said, if greasing threads and re-installing doesn't work, toss it and buy a new one for $17.
    "Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital." - Aaron Levenstein.
    "With
    -- DCGriz, RBR.
    tlg
    tlg is online now
    May 2011
    Jenson has about the most expensive shipping of any retailer.
    $7.95 to ship a tiny BB. So really... it's $24.95 to be exact.
    Plus.... "This product is currently out of stock"
    Nov 2014
    ***Update***
    Yesterday I was doing some short standup climbs when the groan returned. This time I thought I could feel it in the bars. When home I decided to increase the brake caliper clearances. Today's ride was hilly with multiple standup climbs. NO NOISE!
    Really prefer to have tighter caliper clearances with my brakes, but the noise was most annoying and couldn't have been good for my wheelset. Who knew my carbon frame was a wet noodle.
    Probably wheel flex, not frame flex. Maybe.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    GKSki,
    What wheel set is this? What is your spoke count?
    "With
    -- DCGriz, RBR.
    Nov 2014
    CX could easily be correct. Chances are if it is, it's the front wheel as I feel the vibration in the bars. Wheelset is Fulcrum 5s.
    In any event, no more noise but perhaps compromised braking. I'll have to slowly dial back the caliper clearance till I get the best braking/no rubbing that I can.
  1. Groan.........relationship question.
    By Brick Tamland in forum The Lounge
    Last Post: 01-18-2011, 03:25 PM
  2. Road Bike Review Jersey at Roan Groan RR
    By Speedi Pig in forum Racing, Training, Nutrition, Triathlons
    Last Post: 06-25-2006, 11:10 AM
  3. Help: creaky groan from Ksyrium SL rear hub
    By alibaba93 in forum Wheels and Tires
    Last Post: 05-30-2005, 08:27 AM
  4. Shimano Bottom Bracket Installation
    By utbiker in forum Components, Wrenching
    Last Post: 07-23-2004, 04:47 PM
  5. Hey Carbon110 (and others), how did your Roan Groan go?
    By AllUpHill in forum Racing, Training, Nutrition, Triathlons
    Last Post: 06-17-2004, 02:28 PM
