Shimano DI2 hacks
Results 1 to 3 of 3
    Mar 2019
    Shimano DI2 hacks
    I have a road bike fitted with Ultegra R8000 Hydraulic groupset. I want to change the front and rear mechs to DI2 but given the cost of changing the shifters to DI2 versions I am looking for a hack that would allow me to retain the existing mechanical shifters to operate the hydro brakes, and instead use the R600 climbers satelite shifters, incorporated into the hoods or under the bar tape, to operate the front and rear DI2 mechs. This will keep the conversation costs down, requiring (I presume) only the purchase of the satellite shifter, the under stem junction box, a battery, the mechs and wiring loom. I know the TRP guys have a Tube video showing something similar for converting the Hylix brakes, so my question is has anyone else done the conversation Ive described above and if it worked successfully can they give details of how they did it. I realise it will require 2 R600s to be used, one on the left for the front mech and the other on the right for the rear mech, but Id also like to wire in simple momentary switches onto the tops to work in unison with the R600s.
    'brifter' is a lame word.
    Quote Originally Posted by auldain View Post
    "Conversation"? I know what you mean but come on. I don't think the R600 will shift a front derailleur, it only works w/ the rear.
    I work for some bike racers
    and a bunch of skateboards
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Well....if the Di2 system was set for full synchro shifting--you could do everything from the R600.
    Some Di2 button systems are rear-specific and some aren't. Never played with an R600, although IIRCthe R610 sprint shifters are rear-specific IIRC, whereas the R671 TT shifters aren't.
  1. The Real Paranoia-Inducing Purpose of Russian Hacks
    By etane in forum Politics Only
    Last Post: 06-08-2017, 11:21 AM
  2. money saving hacks.
    By rickz in forum General Cycling Discussion
    Last Post: 09-05-2016, 12:38 PM
  3. Zwift hacks - For those without a supported trainer or power meter?
    By SNS1938 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 06-29-2015, 03:56 PM
  4. DrRoebuck Presents: Bike Hacks, Lesson 2.
    By DrRoebuck in forum Commuting, Touring and Ride Reports
    Last Post: 06-06-2008, 07:15 AM
  5. Landis buddy hacks French anti-doping server?
    By Fredke in forum The Doping Forum
    Last Post: 11-15-2006, 10:01 AM
