Shimano GRX RD-RX400 RD w/ 11-42 cassette
Results 1 to 4 of 4
    Sep 2008
    Has anyone tried the Shimano GRX RD-RX400 rear derailleur with an 11-42 cassette? I am currently running a 1x11 using Ultegra 6800 shifters and rear derailleur with a WolfTooth Road Link and an 11 speed 11-42 MTB cassette (w/ 42T front chainring). It has trouble dropping into the 11 tooth ring sometimes while riding, so I am looking for a setup that doesn't rely on the Road link. I know the GRX RD-RX400 is only rated to 36T max, and the GRX RD-RX812 is for 42; but shimano is very conservative with capacity, so I am guessing it would work, and be a less expensive option. I also know that the RD-RX400 is sold as a 2x10, but it uses the same cable pull as 11 speed (like the older Tiagra group before it).
    Sep 2008
    I installed the Shimano RD-RX400 today with the ST-6800 shifters and the 11 speed 11-42t cassette (1x setup w/ 42t front chainring). It shifts through the whole cassette with b-tension screw almost all the way to its max. It easily clears the 42t cog on the cassette.
    So far it shifts a bit rough at either the low end or the high end depending on adjustment. Time will tell if it is better than the RD-6800 derailleur and Wolf Tooth road link, which had the same issue with the 11-42 cassette.
    It definitely shifts worse with the the clutch on than with it off.
    So, I don't recommend it for the 11-42 cassette, but it would be a decent budget solution for either a 11-36 or 11-40 cassette with existing 11 speed shifters.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Not ideal, but the important thing is the chain is still long enough so it doesn't bind on the largest cog with potentially disastrous consequences. My guess is the chain is pretty slack on the 11 cog.
    Yes, Shimano is conservative in their ratings and shift quality will deteriorate the further away from spec you go. Right now, I am running an 11-34T cassette on my gravel bike 5800 groupo where that rear derailleur is rated for 32T max. Shift quality is flawless, but that's only a 2 tooth difference. In your case, we're talking about a 6 tooth difference which is pretty drastic.
    "With
    -- DCGriz, RBR.
    Sep 2008
    The GRX 400 shifters (just like the latest versions of Tiagra) use 11 speed technology in the rear derailleurs, but just pull more cable to shift to ten speed (than Shimano's 11 speed shifters do).* Therefore the 10 speed Tiagra and GRX 400 can use 11 speed rear derailleurs and vice versa.* But it's not officially supported.
    *Where did you see the RX400 cable pull is the same as 11 speed? That's not reflected in the Shimano compatibility chart (unless I'm reading them wrong)..*
  1. differences between the Shimano GRX RX400 and RX600 groupsets?
    By Erik_A in forum Components, Wrenching
    Last Post: 01-02-2020, 06:40 AM
  2. Replies: 1
    Last Post: 01-01-2020, 06:26 PM
  3. Shimano GRX Gravel specific groupset
    By Srode in forum Gravel Bikes
    Last Post: 06-07-2019, 10:27 AM
  4. Shimano GRX gravel components
    By jetdog9 in forum Shimano
    Last Post: 05-09-2019, 01:40 PM
  5. Chain rings: OK to go from 42/30 to 42/26?
    By pdxtim in forum Components, Wrenching
    Last Post: 11-24-2004, 01:38 AM
