Shimano HG95 chain
Results 1 to 9 of 9
    Nov 2002
    Shimano HG95 chain
    I bought a couple of Deore XT HG95 10 speed chains. They did not come in a retail package and have a short installation pin instead of the long break-off style I'm used to. Is this pin any good? Did I get an OEM chain?
    Also, what is Sil-Tec? Is it a grease or a plated-on coating? Can degreasing the chain in OMS and Simple Green remove it? Is it any good as opposed to a lube like Smoove? (This is for mountain and gravel bike use.)
    'brifter' is f'ing stupid
    I've never seen a Shimano chain w/ a pin like that.
    #promechaniclife
    Nov 2002
    Shimano HG95 chain
    Hope I didn't get a counterfeit chain. I'm not even sure where I got them from, as I've had them for a while. Maybe I should use a quick link instead...
    Reputation: velodog's Avatar
    Sep 2007
    What could possibly go wrong.
    Just soft pedal.
    Too old to ride plastic
    Nov 2002
    I don't think it's a counterfeit chain, as it looks identical to one I have in a retail package, except for that pin and the retail one says RE Japan and the other says NF Japan.
    Nov 2002
    Just soft pedal.
    Well, it's my son's bike...
    I think it's fine as long as I didn't damage the link when I pushed the rivet through. I'll take a look. Some Googling found that oem chains come that way, and may use a special rivet tool to keep things lined up.
    Oct 2013
    I wouldn't chance it, just put in a quick link. You know how much a trip to the dentist is going to cost?
    BANNED
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    That pin looks used - as if it was pushed out of an existing chain. Throw that s**t away.
    I would get a good pin, or as Duriel said, use a quick link.
    Not to mention that in the age of C-19, you don't want to go anywhere near a doctor or dentist unless absolutely necessary.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    To be repeatedly redundant, use a quick link.
  1. Original Park CT-3 chain tool and Shimano 11 speed chain?
    By Sven_Nijs in forum Components, Wrenching
    Last Post: 10-22-2014, 12:30 AM
  2. Shimano 105 chain vs Ultegra chain???
    By vontress in forum Components, Wrenching
    Last Post: 03-30-2011, 10:02 AM
  3. 10 speed Shimano chain pin on 10 speed SRAM chain?
    By JoelM in forum General Cycling Discussion
    Last Post: 08-17-2010, 03:58 PM
  4. Chain, chain, chain...
    By brujenn in forum The Lounge
    Last Post: 07-30-2009, 05:59 AM
  5. Need help from chain gurus (connex link+ record UN and shimano chain)
    By hppy4u in forum General Cycling Discussion
    Last Post: 10-23-2008, 06:54 PM
