Shimano long cage with smaller cassette?
Results 1 to 5 of 5
    Sep 2005
    I have a 'climbing bike' set up with a long cage Ultegra (RD-R8000-GS) and 11-34 cassette (52/36 crankset). Shimano lists a "low sprocket" range of 28-34t for that RD. Why spec a low sprocket min? From what I've understood, a long cage RD should be able to handle shifting a smaller cassette (assuming proper chain length for that setup). Does Shimano think the world will end if I use an RD-R8000-GS with a 12-25 ?
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    That will be just fine, adjust the b-tension screw, and you are good to go.
    Feb 2002
    Quote Originally Posted by rideit View Post
    Yup. Not an issue.
    'brifter' is f'ing stupid
    Just in case you were still wondering it will be fine.
    #promechaniclife
    Sep 2005
    Thanks for the replies. Older Shimano RD specs would list capacity, largest sprocket, and smallest sprocket, but this was the first time I noticed a "min large sprocket" spec.
    I need to stop reading Shimano tech docs
  1. Replies: 16
    Last Post: 06-17-2015, 05:59 PM
  2. smaller butt equals smaller saddle?
    By RedVernice in forum General Cycling Discussion
    Last Post: 06-05-2011, 04:12 PM
  3. Long cage vs. short cage
    By triton in forum Components, Wrenching
    Last Post: 02-15-2006, 05:30 PM
  4. Rear Derailers - short cage vs. long cage
    By ravenmore in forum Components, Wrenching
    Last Post: 03-18-2005, 04:41 PM
  5. Long cage - short cage...
    By TurboTurtle in forum Components, Wrenching
    Last Post: 08-05-2004, 05:21 PM
