Shimano Master Link
Results 1 to 8 of 8
    Feb 2006
    Shimano Master Link / Ultrasonic Cleaner
    Finally worked my way into 11 speed and low and behold a master link for Shimano.
    New thinking ultrasonic cleaner now with Shimano removable.
    Anybody ultrasonic cleaning chains?
    Reuse Shimano link?
    Thinking maybe next level chit here....
    'brifter' is f'ing stupid
    Technically no. They're 'single use' according to Shimano. If you plan on cleaning your chain a bunch I'd say maybe replace it every other time. I definitely wouldn't go out and buy an ultrasonic cleaner just because I have a Shimano chain w/ a connecting link...that's just stupid. Clean it on the bike w/ some degreaser and a soapy sponge.
    #promechaniclife
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    I have an ultrasonic cleaner, I use it very, very sparingly. It is a handy tool, but itís not great to completely flush your chain of all lubricant in the rollers and pins. That said, I have certainly reused shimano links, but I usually just put them in the tool bag for emergency repair duty.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    I reuse Shimano and KMC links a couple times. Should you? Technically no. But I've never had one break. I've only ever broke a chain once (not at a quick link).
    I have an ultrasonic cleaner and use it occasionally for chains and cassettes. I get a lot of miles from a chain, and rarely clean it. So usually half life I put it in the ultrasonic for a good clean.
    Here's a tip: Put the chain in a zip lock back. Fill the bag with simple green. Put that in your ultrasonic cleaner filled with just water. It works just as well and clean up is a snap. You cleaner doesn't get dirty at all.
    Quote Originally Posted by rideit View Post
    I keep a couple used ones in my bag in case of emergency. They're good enough to get you home. I've saved a few friends rides with them.
    Sep 2011
    and how/where do you discard the Simple green sludge afterward? All the guys i know use rags to clean their chains and they just throw it in the trashcan, ugh not environmently friendly?
    tlg
    tlg is offline
    May 2011
    I pour it in with my motor oil when I take it to recycle.
    Nov 2002
    You're polluting the waste stream when you do that!
    Nov 2002
    As long as you have to snap the link together with force, like having to stand on a pedal, I think the link is still good.
  1. Replies: 27
    Last Post: 07-06-2016, 06:45 AM
  2. Replace dud Shimano "Replacment Chain Pin" with a Master Link?
    By bikeshopper7 in forum Components, Wrenching
    Last Post: 06-04-2009, 12:29 AM
  3. Colnago Master vs. Master Light
    By karlug in forum Retro-Classic
    Last Post: 10-22-2007, 06:22 AM
  4. Colnago Master X- Light or Master Carbon ?
    By manandjoe in forum Bikes, Frames and Forks
    Last Post: 04-10-2007, 06:50 AM
  5. Please PLEASE someone help me with the master link
    By Speed_Metal in forum General Cycling Discussion
    Last Post: 09-22-2004, 06:19 PM
