Shimano R8070 Hydraulic Disc Problems
Results 1 to 14 of 14
    TheKing
    Jan 2019
    I had a road bike built this spring with Shimano R8070 disc brakes. Since day one I have not been impressed with the performance of these brakes. The travel on the brake levers is huge. At full brake I have less than an inch of distance between the lever and handlebars. The rear brake has failed twice to the point where at full brake it could not stop the wheel. I had it back to the shop twice at which time they did a brake bleed and said it was probably air in the system. It would work fine for a few weeks and then braking performance would deteriorate. There are no signs of fluid leakage. Recently the front brake has started to fail similar to the back. If I pump the levers several times it seems to bring back sufficient braking to do a ride. I do hang the bike by the wheels, but I also do the same with my gravel bike equipped with SRAM disc which works perfectly and has far greater breaking capacity. I am at a loss as to what to do next. I wanted to contact Shimano to inform them of this issue, but could not find a contact method. They show no R8070 recall notices on their website. Any ideas would be appreciated.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Definitely sounds like you have air in the system, those brakes are very strong, they should bring you to a stop quickly (as long as you're not compressing air that is). You should check line fittings and bleed/reservoir screws and bleed both again, even a little air in the system will decrease performance, the fact that you hang the bike from the wheels should make no difference.
    Let us know what you find and good luck.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Oct 2013
    Quote Originally Posted by upstateSC-rider View Post
    Only in a perfect world, if there are some issues, hanging could definitely cause those problems to present themselves.
    BANNED
    Reputation: nova_rider's Avatar
    Sep 2005
    From Shimano dealer service manual:
    "This disc brake system is not designed to be turned upside down. If the bicycle is turned upside down or on its side, the air bubbles inside the reservoir tank may move in the direction of the calipers."
    Sounds like the problem IS with how you're storing the bike.
    'brifter' is f'ing stupid
    OP: Sounds like your shop doesn't know how to bleed Shimano brakes.
    Brakes.
    Not breaks.
    #promechaniclife
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Spelling is his Achilles’ heal.
    Aug 2004
    Quote Originally Posted by nova_rider View Post
    I stand corrected.
    Have the brakes re-bled and store the bike rubber-side down and see if it helps.
    Good luck
    Quote Originally Posted by rideit View Post
    I sea what you did there.
    #promechaniclife
    Sep 2011
    I'm surprised this is still an issue after over 2 decades of disc refinement in the mtb world. So no flipping the bike over when changing a flat then? I think you can flip the bike over, just don't flip it over while pressing the brake lever because that will definitely pump air into it if the reservoir is not full.
    You should never flip a bike upside to remove/install a wheel anyway...doesn't matter what kind of brakes you have.
    #promechaniclife
    Sep 2011
    This truth is going to hurt some people.
    Sep 2005
    Since most hydraulic brake systems are not hermetically sealed, there will always be some air in the reservoir and no amount of refinement will fix that. If the bike is flipped only for short period, such as changing a flat, the small amount of air won't have traveled too far up the system. However, if left upside down for an extended period, the air WILL travel to the highest point in the system, which is likely the caliper.
    Oct 2013
    That is so embarrassing for the bike!
    BANNED
    TheKing
    Jan 2019
    This summarizes my thoughts on this issue. I have a hard time accepting I can't hang my road bike upside down next to my other bikes with hydraulic brakes or lay it down in my car. Apparently this bike does have some air in the system that moves to the caliper when inverted. I believe that having a reservoir fully filled can avoid this problem. I will do a thorough bleed and finish with a full reservoir and then hang the bike up and see what happens.
  1. Replies: 27
    Last Post: 04-23-2017, 04:57 PM
  2. Shimano Hydraulic ST-RS685 or Sram Hydraulic
    By Kuna in forum Cyclocross
    Last Post: 07-24-2015, 05:43 AM
  3. Shimano Hydraulic Road Disc Brakes. Hang Bike Upside Down?
    By Russlite in forum Components, Wrenching
    Last Post: 05-29-2015, 10:03 AM
  4. Replies: 32
    Last Post: 01-25-2015, 11:58 AM
  5. How long do Shimano hydraulic road disc pads last?
    By wgscott in forum Components, Wrenching
    Last Post: 10-06-2014, 04:54 AM
