Shimano Shifter Cables with Jagwire Housing
Results 1 to 3 of 3
    I have a Jagwire housing and cable kit and noticed the inner shifter cable is listed as 1.1mm. Presumably the Jagwire housing is designed to work perfectly with that.
    Shimano inner cables are listed as 1.2mm.
    Will Shimano inner replacements work just fine with the Jagwire housing or will the Jagwire housing be .1 to small and effect things?
    I plan to use the Jagwire cables to start with.......but I have a stock of Shimano inners that I want to be able to use when it comes time to replace the inner (an not the housing).
    Thanks
    Apr 2015
    I've got Jagwire 4mm housing with Shimano Dura Ace shift cable on a SRAM Force setup. Has always worked fine for me.
    Quote Originally Posted by biner View Post
    Thanks. I'm guessing it would be common knowledge if it wouldn't work well. Good to hear first hand it does.
  1. Jagwire Link style cable housing for Di2?
    By EightOhEight in forum Components, Wrenching
    Last Post: 09-05-2014, 09:42 AM
  2. Question about Package of Jagwire Pro Cable Housing
    By armstrong in forum Components, Wrenching
    Last Post: 06-21-2014, 06:16 AM
  3. Replacing cables & housing - Jagwire Racer kit
    By thatdrewguy in forum Components, Wrenching
    Last Post: 03-07-2012, 01:15 PM
  4. Jagwire cable housing
    By dasho in forum Components, Wrenching
    Last Post: 09-25-2011, 02:10 PM
  5. $2 Cables vs. $5 cables and 5mm vs 4mm housing
    By tjanson in forum Cyclocross
    Last Post: 08-05-2009, 01:20 PM
