Shimano shifter eats another rear cable.............. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 91
  1. #26
    Apr 2011
    The newer Campy Chorus set is certainly enticing with the 12 speed and it even has a 48/32 crankset option and 11-34 cassette option. Not sure I like the idea of carbon crank arms though. And of course as I said before, wouldn't that necessitate changing the cassette carrier on my wheelsets?
    I've been using Campy carbon crank arms for 3 years. Why, did you hear some things from other users?
  2. #27
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by bvber View Post
    I've also got a Campagnolo carbon crank, Chorus with over 16,000 miles and no issues.
    Too old to ride plastic
  3. #28
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Can't say that I have. I guess it's just a gut feeling about putting that kind of force on something thay is essentially plastic. But hey, if it works, it works.
    "With
    -- DCGriz, RBR.
  4. #29
    Oct 2017
    Quote Originally Posted by jetdog9 View Post
    @Lombard, PM me your address and I'll mail you a meter of cable housing liner to user for swapping cables. It makes changing internally routed cables super easy. Had to purchase 30m worth, so have some extra...
    In this video, see from ~0:50 to ~1:20:
    Are we just gonna ignore the fact that this guy has a Dura-Ace flashlight?
  5. #30
    Oct 2013
    I'm going to go with CF being stronger than steel/wt. But they guy probably has some big thighs, post them up!
    BANNED
  6. #31
    'brifter' is f'ing stupid
    Existing cassettes, really? How about existing crankset? That would be nice if I could do that - only have to replace shifters and derailleurs!
    Point taken about going to 12-speed would be more hassle. I don't know if cassette carrier width is wider or if the cogs are just thinner or a combo of both.
    If Campy is Rolex and SRAM is Omega what is Shimano, Timex? They do take a lickin' and keep on tickin'. The cable eating shifter is really the only sore spot on an otherwise excellent groupo.
    That being said, I did recently convert an older mountain bike to a 9-speed SRAM X9/X7 mix and the shifting there is superb! I previously had frustrating ghost shifting on a Shimano Deore I could not track down even after chain, cassette, rear derailleur, cable and housing replacements.
    Hmmmm...I was mainly thinking about the attitude that goes w/ the product but good question. I'd probably say something like Grand Seiko.
    All 11 speed stuff is so close now they're interchangeable. Your crank will work fine.
    #promechaniclife
  7. #32
    Apr 2011
    Well, if you ride a carbon fiber frame bike...
  8. #33
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Quote Originally Posted by Finx View Post
    Totally noticed that. Fun to have in-industry tchotchkes. Wonder if he got it from a Shimano rep or at like Interbike or something.
    Can only imagine what oddball cool stuff cxwrench might have.
  9. #34
    Depends how they are made but no carbon would actually be much stronger with regard to force and fatigue.
    Carbon is essentially plastic about as much as a gin & tonic is essentially water. For lack of a better analogy where adding something totally changes it.
  10. #35
    Banned Sock Puppet
    May 2014
    True, but I got over that one long ago.
    LOL! Actually a good analogy. Shows how reality is so often clouded by perception.
    "With
    -- DCGriz, RBR.
  11. #36
    Banned Sock Puppet
    May 2014
    Thanks CX! Other question is can I keep my Ultegra brake calipers?
    "With
    -- DCGriz, RBR.
  12. #37
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    A better analogy would be... like saying Reinforced Concrete is essentially 'Steel'. Which would be silly. It's 'essentially' ~70% rocks. Held together with cement. And reinforced with steel rebar. Making it the #1 building material in the world.
    Carbon, aka Carbon Fiber, aka CFRP (carbon fiber reinforced polymer) is essentially ~70% Carbon, or Atomic #6, or C. Held together and reinforced with polymers (plastic)
    Oh and that Reynolds 'steel' is real bicycle.... it's essentially ~70% iron. Who would ride an iron bicycle?
  13. #38
    Oct 2013
    Carbon>Iron. The only way to fly!
    BANNED
  14. #39
    Apr 2011
    The early Ironman competitors?
  15. #40
    Not really all that much...an XTR bottle opener, a neat little SRAM mini tool, a Bontrager flashlight that doesn't work, some glasses and coffee mugs, mostly stuff like that.
    #promechaniclife
  16. #41
    Yeah, they might feel a little different but they'll still work. Cable pull ratios don't change that much.
    #promechaniclife
  17. #42
    Banned Sock Puppet
    May 2014
    Thanks CX! This may be a good winter project for me - especially of there is no ski season due to the plague.
    "With
    -- DCGriz, RBR.
  18. #43
    Banned Sock Puppet
    May 2014
    Carbonman just doesn't sound right.
    "With
    -- DCGriz, RBR.
  19. #44
    tlg
    tlg is offline
    May 2011
    Contrary to the name, iron is pretty soft and weak. Other than cookware, fences, and cheap castings, it's not used for a whole lot.
    When you want something hard and strong... iron is about the last thing you turn to.
    FYI... diamonds are 100% carbon. Carbon is #6 on the periodic table... Iron, #26.
  20. #45
    Reputation: Srode's Avatar
    Aug 2012
    Yeah, those are crap cables - go back to the coated cables and lube up the area using the Shimano cable lube (not just any lube) where it goes through the shifter, check the spool for debris and scratches, and replace your outer cable. That kind of life is just insane. The design definitely has some issues and will fail cables sooner than desirable but 800 miles is not just the design, you have other issues.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
  21. #46
    Banned Sock Puppet
    May 2014
    Precisely why we have alloys of different metals. Although automobile engine blocks and even heads used to be primarily cast iron. True that pound for pound, iron isn't that strong, but it is tough. They are mostly Al now to reduce weight and dissipate heat better.
    Considering you are an engineer (I think), I am assuming you meant this comment as tongue in cheek. Lithium is #3 on the periodic table. Does that mean it's stronger than carbon?
    "With
    -- DCGriz, RBR.
  22. #47
    Apr 2011
    For now. There is a bit of a lag in public's perception. I was watching The Cars That Made America on History Channel and there is a term "too futuristic" mentioned in design that didn't sell well.
  23. #48
    Oct 2013
    NO! ... and NO! again
    BANNED
  24. #49
    tlg
    tlg is offline
    May 2011
    Pure iron isn't all that tough. Most iron that's used in manufacturing is still some form of alloy (wrought iron, cast iron, ductile iron, malleable iron, grey iron) none are pure iron. They all have carbon added to give them strength and hardness. Which is of course is what steel is, iron with carbon (and other stuff) added. High carbon steel, being the strongest and hardest.
    Yes I am... and $#it at chemistry. It was tongue in cheek.
    The order generally coincides with increasing atomic mass.
  25. #50
    Oct 2013
    In chemistry, the available bonds are more an indication of strenght, it's complicated.
    BANNED
  1. Having a problem threading shifter cable on a rear 6700 Ultegra shifter?
    By Haystack Calhoun in forum Components, Wrenching
    Last Post: 11-08-2015, 11:44 AM
  2. Shifter cable jammed into shifter
    By dasho in forum Components, Wrenching
    Last Post: 09-10-2011, 01:05 PM
  3. Shifter Cable Head Stuck in Shifter
    By bent_spoke in forum Components, Wrenching
    Last Post: 06-02-2009, 12:41 PM
  4. Cable Wear - Shimano ST-6600 10 spd Rear Shifter
    By Singlespeed10 in forum Components, Wrenching
    Last Post: 03-26-2008, 09:44 AM
  5. Another Hot Dog Eats the Wienie
    By refund!? in forum Politics Only
    Last Post: 05-17-2007, 06:10 PM
