Shimano and SRAM Disc Rotors exchangable?
Results 1 to 19 of 19
    Aug 2016
    Hi all,
    My son has a Giant TCX SLR that came with Shimano 105 Disc (140mm Rotors), I have a TCX Advanced that has SRAM Rival 1 (140mm Rotors). I wonder if I could use my wheels on his bike without having to change the disc rotors, and vice-versa. Sorry for the newbie question
    Oct 2013
    That would be pretty easy to just try and DO IT! ...to see if it would fit. Don't test ride it down a mountain on the first ride.
    BANNED
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Yes you can use them... however, it's highly likely you'll get brake rub. You may have to re-center your brake caliper when you swap wheels.
    Aug 2016
    I was looking at giant's website and maybe the disc rotor that comes on the Shimano 105 equipped TCX SLR are Giant's own disc rotor, part of the Giant Conduct Hydraulic Brake system. May not be Shimano at all....
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    The answer is maybe. The brake track area is different from one manufacturer to another. Make sure that the pad contacts the rotor completely and does not over hang.
    Sent from my SM-G930V using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    'brifter' is f'ing stupid
    They are definitely designed to work *best* when used as a system. All of the manufacturers will say no, only use their pads/rotors together. I've seen plenty of bikes where they were mixed and no one has died yet.
    #promechaniclife
    Jul 2017
    I am using the new Shiman Dura Ice rotors on my new rims with Sram brakes. No problem execpt that I had to recenter my brakes which was probably due to the new wheels.
    Not a climber
    Reputation: dcorn's Avatar
    Sep 2011
    Generally yes. I have two sets of wheels for my CX bike, which are both Sram rotors, but I swap the wheelsets without messing with the brakes at all. I also straight swapped a set of new Sram rotors in for the stock Shimano rotors on my road bike, no adjustment needed.
    Jul 2017
    Spacers are also available from Boyd Cycling ( and others ?) if needed to change the offset on the discs.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Interesting.
    On a slightly different subject, I know awhile back you said not to "cross fluids" - not to use DOT fluid in a Shimano system or mineral oil in a SRAM system. Do you know why this is?
    "Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital." - Aaron Levenstein.
    "With
    -- DCGriz, RBR.
    Interesting.
    I did? The systems are designed around their respective fluids. I'd guess you could get away w/ mineral oil in a SRAM system but if you put DOT fluid in a Shimano system you'd ruin all sorts of stuff in a heartbeat because it's a much more corrosive liquid.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    Interesting? So I guess DOT has a higher boiling point (I think that's why it's used in cars) at the expense of being more corrosive?
    "With
    -- DCGriz, RBR.
    Rub it............
    Nov 2007
    And it has a lower freezing point as well.
    No, mineral oil and the DOT that is used in bicycle brakes has a nearly identical boiling point, sometimes the mineral oil BP is actually a few degrees higher. The DOT I use in my car and moto is much higher, but not the stuff that SRAM use.
    #promechaniclife
    Nov 2002
    Corrosive? Maybe to paint but if that were true, automobiles would be losing their brakes and crashing all over the the place. Rubber parts have to be compatible with the fluid. That's the real issue.
    Banned Sock Puppet
    May 2014
    Hmmm. It sounds like SRAM could use anything, but chooses to spec DOT fluid (probably their own) because they can charge more for it?
    "With
    -- DCGriz, RBR.
    Definitely not. You don't think SRAM actually make their own, do you? It might be formulated to their spec, more likely they just determined what they needed and bought it. Brake fluid w/ 'normal' boiling point temps is cheap...really cheap. It's only the super high boiling point race fluid that's expensive.
    #promechaniclife
    Yes, corrosive. Mostly to paint and surface finishes. It's got ingredients to make it non-corrosive to the metal parts in the system. Not hard to make parts that aren't affected by it. If you use parts ( o-rings/seals/internal parts) that are made to work w/ DOT fluid it's not an issue.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    Good point.
    Understood.
    "With
    -- DCGriz, RBR.
  1. Disc brakes road bikes - pad/rotors touching
    By machoman in forum General Cycling Discussion
    Last Post: 04-07-2015, 09:51 AM
  2. Anyone run 140mm disc rotors up front?
    By Shogunade in forum Components, Wrenching
    Last Post: 10-07-2014, 04:48 PM
  3. Disc brake rotors for cross & general riding
    By deviousalex in forum Cyclocross
    Last Post: 08-20-2014, 10:03 PM
  4. Replies: 12
    Last Post: 09-28-2012, 06:43 PM
  5. sibex cx fork and disc rotors
    By crank it in forum Cyclocross
    Last Post: 10-31-2006, 10:59 PM
