Shimano Ultegra RD-6870-SS rear derailleur compatible with 11-28 cassette
Results 1 to 4 of 4
    Jan 2006
    Can you use an 11-28 cassette with an 11-speed Shimano Ultegra RD-6870-SS rear derailleur (Di2)?
    The Shimano website at product seems to suggest that when your largest cog is a 28, the smallest that a cog can be is 12 teeth. Or perhaps I'm reading it wrong.
    The same question would apply, I suppose, to an 11-speed Shimano Ultegra RD-6800-SS rear derailleur (mechanical).
    FWIW, the setup I'm proposing to use is a 50-34 with an 11-28 cassette, which would not exceed the total capacity that Shimano specifies for this derailleur.
    Thanks in advance!
    Apr 2006
    It's fine. Should be no problem whatsoever.
    Forever a Student
    Mar 2014
    you're reading it wrong.
    it was designed to work with that cassette, you're good to go.
    use a torque wrench
    Jan 2006
    Thanks for the reply. How do you read this then?
    Maximum Sprocket low: 28T, top:12T
    Minimum Sprocket low: 23T, top:11T
    (From: product)
  1. Will Shimano 105 rear derailleur accept sram 12-32 cassette?
    By Junior77 in forum Components, Wrenching
    Last Post: 05-01-2015, 08:36 AM
  2. Replies: 6
    Last Post: 03-12-2013, 02:57 PM
  3. Replies: 4
    Last Post: 10-28-2012, 08:19 PM
  4. Shimano 9sp rear derailleur / 10sp cassette
    By ts8169 in forum Components, Wrenching
    Last Post: 08-27-2012, 06:21 AM
  5. Question about using Shimano Ultegra SL rear derailleur
    By lockwood1 in forum Components, Wrenching
    Last Post: 05-25-2009, 10:13 AM
