Shimano Ultegra RD-R8000 Upshift Problem
Results 1 to 15 of 15
    Nov 2019
    Shimano Ultegra RD-R8000 Upshift Problem [SOLVED]
    [SOLVED: The problem was a combination of the rear derailleur cable slack slightly out of adjustment and the front derailleur slightly rubbing the chain when the big front chainring was in use with the mid to small cassette cogs. I added a 1/2 turn to the front derailleur extension limit screw and now everything works well and is quiet. Thanks for the help.]
    I have a new bike with a Shimano Ultegra RD-8000 rear derailleur and 11 speed cassette that shifts perfectly when moving to a higher gear ratio (smaller sprocket) but when shifting the other direction the chain runs noisily.
    I can't adjust the cable tension to quiet the drivetrain after downshifts. I verified the noise is coming from the rear of the bike. The rear derailleur overtravel limits are set correctly for high and low.
    On my other bikes I could always get the drivetrain to run quietly. Any suggestions to why upshifts would be noisy and downshifts perfect? Thanks in advance.
    Sep 2005
    Does it get “worse” as the cogs get larger (25 teeth vs 19 teeth for example)? If so, I’d look at the b screw setting.
    Nov 2019
    No, it's noisiest on the mid to small cogs using either chainring.
    It's possible the cable is too tight. I'm going to add a little slack and readjust. I'll report back.
    Sep 2009
    Maybe hanger alignment issue?
    Nov 2019
    Do you have a technique to verify the hanger alignment other than eyeball?
    Nov 2019
    After playing with the rear derailleur adjustment I found that when shifting to a lower gear (larger cog) if I push the shift lever well beyond the index click, but short of the second click, the drivetrain shifts and runs quietly. If I just push the lever to the first click the bike will shift but the drivetrain run noisy. Is this normal?
    'brifter' is f'ing stupid
    Quote Originally Posted by RobRob View Post
    Shifting to larger cogs...easier gears...is downshifting, not upshifting. It does sound like either a hanger alignment issue or your tension is off a bit.
    #promechaniclife
    Sep 2015
    On my new road bike I had something similar. My bike is 9-speed Sora It shifted to higher gears fast, but shifting to lower gears was harder. Just clicking (up cassette) one click, the derailleur wouldn't shift down sometimes. When it didn’t go down one gear, I had to click one more time, then it would go down 2 gears and I would then shift up one gear to get the gear I wanted. I then changed wheels and moved my cassette to the new wheel and torqued it to per Shimano spec. (30 NM). Now the bike shifted down correctly but doesn't shift up as fast as before. The factory over torqued the cassette and it didn't match the shifter's indexing.
    Quote Originally Posted by ra21benj View Post
    This was not the reason.
    #promechaniclife
    Sep 2015
    The only thing I changed was the new rear wheel (with correct cassette spacer) and now the bike downshifts correctly. I didn't change the rear stop screws,the b screw setting, or the shift cable tension.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    The torque on the cassette was not the problem. It would not change the indexing.
    Something else was the problem... like...oh.... maybe.... 'correct cassette spacer'
    Sep 2009
    Hanger alignment tool is the only way I know to get it right. In my experience eyeballs only see misalignment that is very bad and are not very helpful at fixing it.
    I made my own tool out of a length of 1" steel tube with a hole drilled in one end to fit a bolt that screws into the derailleur mounting hole. A fine thread bolt to match the derailleur bolt and a few washers to space the tube out. I use a tape measure and measure the distance from the rim to the other end of the steel tube and adjust the hanger until the measurement is the same all around the wheel.
    Sep 2015
    For the new wheels I used the 9 speed cassette spacer that came with the wheels.
    My original wheels that came with the bike also had a spacer for the 9 speed cassette. Maybe they included the wrong spacer from the factory?
    Your adjustment was off for one wheel and right on for the other. Despite there being standards not every wheel will locate a cassette in the same place.
    #promechaniclife
    Nov 2019
    The problem was a combination of the rear derailleur cable slack slightly out of adjustment and the front derailleur slightly rubbing the chain when the big front chainring was in use with the mid to small cassette cogs. I adjusted the cable and added a 1/2 turn to the front derailleur extension limit screw and now everything works well and is quiet. Thanks for the help.
  1. Shimano's R8000 vs 6800 Ultegra Rear Derailleur
    By ROAD&DIRT in forum Components, Wrenching
    Last Post: 11-19-2019, 10:03 AM
  2. Problem with R8000 front derailleur
    By Ken2 in forum Components, Wrenching
    Last Post: 12-24-2018, 03:48 PM
  3. Shimano Ultegra R8000 drivetrain missed the Boat...
    By factory feel in forum General Cycling Discussion
    Last Post: 04-09-2018, 11:07 AM
  4. Shimano Ultegra R8000 officially announced
    By cobra_kai in forum Components, Wrenching
    Last Post: 06-13-2017, 05:19 AM
  5. Ultegra di2 rear sometimes won't upshift
    By aabbas in forum Components, Wrenching
    Last Post: 12-05-2016, 05:46 PM
