Shimano XTR 9 speeds RD-M970 rear derailleur & XTR 9 speeds 11-34T cassette ???
Results 1 to 7 of 7
    Mar 2013
    I have a Shimano XTR 9 speeds RD-M970 rear derailleur(short cage) and would like to use it for a XTR 9 speeds 11-34T cassette.
    Is it a workable combo ? Or do I need a RD-M971 instead ?
    'brifter' is f'ing stupid
    Quote Originally Posted by edle View Post
    Max cog is 34, so that's good. Capacity is 33, so you need to figure that out.
    #promechaniclife
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    When it comes to MTB derailleurs, never buy short cage.
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro MTB Touring
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    Mar 2013
    'Capacity is 33'....Do u mean the front chainring max. is 33T ?
    Quote Originally Posted by CleavesF View Post
    That's just stupid. If the spec is correct for the application, why not?
    No..."capacity". The difference between the small cog/large cog + the difference between the small ring and large ring. For example:
    11/34 cassette: difference is 23 teeth
    50/34 compact crank: difference is 16 teeth
    23 + 16 = 39 which is obviously more than the capacity of 33 for the GS short cage derailleur. You'd need the SGS long cage, which has a capacity of 43.
    If you were running a single chainring you'd be fine w/ the GS and it's shorter cage, contrary to the incorrect advice provided by the other guy i quoted.
    #promechaniclife
    Mar 2013
    Thanks for the valuable input.
    Yes, I'm planning to run a single ring(28T or 32T) in the front.
    Dec 2010
    970 is Rapid Rise, 971 is regular small cog normal.
    If you are sure you have a 970, then get a 970 with a longer cage, not a 971.
    I use a 971 short cage on my commuter. 44/30 985 crank and 12/27 DuraAce cassette. Works great.
  1. 9 to 10 speeds cassette and settings
    By Paolin in forum Components, Wrenching
    Last Post: 09-27-2012, 06:28 AM
  2. Can 10 speeds crank uses 11 speeds chain rings
    By slowoldman in forum Campagnolo
    Last Post: 05-28-2011, 08:17 AM
  3. do 9 speeds shift better than 10 speeds?
    By pdxtim in forum Components, Wrenching
    Last Post: 10-18-2007, 09:57 PM
  4. Old front derailleur with 10 speeds?
    By Guibarhu in forum Components, Wrenching
    Last Post: 12-30-2006, 06:06 PM
  5. Rear derailleur compatibility, does # of speeds matter?
    By T-shirt in forum Components, Wrenching
    Last Post: 05-29-2005, 01:05 PM
