short stem question
Results 1 to 8 of 8
    Reputation: triscuit's Avatar
    Sep 2004
    short stem question
    Hi, anyone know of a company that makes 70mm road stems, preferably in the 15 degree range? They have become releatively common in mtb, but I can't seem to find a company that makes road stems in this configuration. Thanks.
    Sep 2004
    here's one at 70mm- 10degree
    Quote Originally Posted by triscuit
    That's the closes I can find. Go to fullspeedahead.com
    j-dawg
    Reputation: j-dawg's Avatar
    Apr 2004
    Bontrager/Salsa
    Looks like the both make 80mm in +-15/17. Salsa also makes a 80 in +-25.
    Both are solid and cheap.
    I may be fat but I'm slow.
    n00bsauce
    Reputation: Mel Erickson's Avatar
    I was going to suggest Salsa but dawg beat me to it. aebike.com carries a good selection.
    "Those who can make you believe absurdities can make you commit atrocities." Voltaire
    There are your fog people & your sun people, he said. I said I wasn't sure which kind I was. He nodded. Fog'll do that to you, he said.
    "We are all ignorant about most things."
    Mel Erickson
    possible solution..
    A 25.4mm MTB stem can work with a road bar, merely by filing a chamfer about 1.0-1.5mm wide along the four mating edges with the handlebar, to eliminate the pinch points.
    That said, a frame that needs an extra short high rise stem doesn't fit very well.
    Old and Fixed, Moderator
    Jan 2002
    Another option might be to check out your handle bars. Handle bar reach can vary by over 2cm. Salsa makes the Poco bar that is very short reach.
    Dave Hickey/ Fort Worth
    Sep 2004
    Thanks all. The reality is that very few companies make cx bikes for short people if you don't want toe overlap and you want full size wheels. I think an 80mm, 10 degree would work, so I will check out some of those suggestions. I am currently using a 90mm, 6 degree, and it is okay, but since I am primarily a mt biker, it feels really stretched out. My mtbs have 70mm, 15 degree stems, and it looked like a better fit, but the ones I have don't quite fit the bars.
    Thanks again.
    Try IRD website,
    Google: Interloc Racing and go to their site. Look at their "web store". There are many types of stems in a variety of angles/clamp sizes and models. The A-4 is an excellent stem that can be used for cross country mtb; so it would be ideal for cyclocross. I might reccomend a 31.8 if you are willing to change bars (sounds like a short drop/reach bar like the salsa poco would work well) The 31.8 is nice because there is more surface area to clamp; Although the stiffness/security issue is more about the quality of bar/stem combo than the clamp size.
    The Thomson is likely the strongest and most dependable stem available and is available in a range of models/sizes/angles.....eBay is great for Thomson products
    Hope this helps!
  1. The stem question, again...
    By Farmpunker in forum Components, Wrenching
    Last Post: 04-12-2005, 02:42 PM
  2. Threadless stem question
    By macbugs in forum Components, Wrenching
    Last Post: 10-22-2004, 09:25 PM
  3. Replies: 54
    Last Post: 10-02-2004, 03:37 AM
  4. Question for Ritchey stem faithful
    By Nessism in forum Components, Wrenching
    Last Post: 06-28-2004, 04:25 AM
  5. stem rise & length
    By C-40 in forum General Cycling Discussion
    Last Post: 03-22-2004, 07:33 AM
