Single Speed Conversion
Results 1 to 3 of 3
    Sep 2007
    I'm converting a 1997 Peugeot Hybrid to a single speed. The original deraillure was a Shimano Altus with a rear dropout deraillure hanger setup. I've given up on fiding something to replace the dropout hanger (probably something easy to order that I just haven't found) and am going for a fixed chain length approach.
    The original fron chain crank/chain ring set up was a bit strange with the triple chain ring and crank all one assembly that was welded together -- can't take the chain rings apart from the crank. The bottom bracket is a spindle/ball bearing setup, rather than a cartridge style.
    The question -- any hints about a replacement crank and chain ring? I can always go with the original triple and just use the large chain ring, but it seems tacky. Any thoughts/insights?
    Thanks from a novice wrench.
    Arrogant roadie.....
    Reputation: Dave_Stohler's Avatar
    Does the bike have horizontal dropouts? If it doesn't, you WILL need a chain tensioner to fit where your old dérailleur used to be.
    As far as the welded crank-ring assembly, you can always just elect to leave the chain on the middle ring and just go with that. Otherwise, you'll need to buy a new crankset and a new ring, and swap pedals.
    We are the 801
    We are the central shaft
    duh...
    Jan 2005
    Quote Originally Posted by Dave_Stohler
    not nec... if not he just won't have much choice in gearing
